Old 03-04-2021, 04:33 PM
joeshepard joeshepard is offline
Default Logic Smart Controls and Avid Dock
Has anyone found a way to use the Dock/Avid Control to access Logic Smart Controls?
Thanks,
Joe
MacBook 16" Pro Max 2TB 64GB
Ventura 13.6
Pro Tools Ultimate 2023.12 (Native)
Logic Pro 10.7.9
Eucon 2023.12
2 Artist Mixes
Avid Control on an iPad
Soundflow & Streamdeck XL
UA Apollo|x|16, UA Apollo Twin|x, UA TB Octo Satellite
Old 03-05-2021, 08:52 AM
EddieJones's Avatar
Default Re: Logic Smart Controls and Avid Dock
Are these knob controls? As well as the 5 normal and 5 shifted function buttons(EQ/DYN/PAN etc.) there are more if you press and hold these buttons, the LED will flash after you have held it long enough. They could be in those.
Old 11-14-2022, 06:40 PM
simcc simcc is offline
Hi, has anyone found out if this is possible with the S1?
For example on an X-touch (and presumably most Mackie Controls?) you press Shift+INST, and that gets you to smart controls, which you can then flip onto the faders. Nice.
I tried holding down buttons on the Artist Mix...did nothing.
Old 11-14-2022, 10:24 PM
mattrixx mattrixx is offline
Yeah, it's a bit of a strange one.
You can move the smart knobs in logic and Eucon will recognise the change in realtime, however even, while editing the value of an insert for example with the Smart Controls open on Logic, they won't respond to the plugin being changed by Eucon, even though the plugin itself is.
Hope that makes sense.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 11-15-2022, 12:51 PM
Ha, I know exactly what you're talking about actually...yeah I've noticed that, it is odd.
But what I'm asking is, can you control the smart controls directly from the S1? As you can with a Mackie Control (X-touch)...
I just bought the X-touch for this purpose, and while it works great, the faders are very jittery compared to the Artist Mix...half thinking of returning it and upgrade to a S1.
Old 11-15-2022, 02:05 PM
I don't have an S1. I have an S3 and you cannot, so I suspect it would be the same with the S1.
I'll take a closer look later this morning, to see if there's an alternate method.
Matt McKenzie-Smith
mattrixx.net
Old 11-15-2022, 02:27 PM
EddieJones's Avatar
This would have to be implemented by Apple. Ask on their forums, that sometimes ad stuff.
Old 11-15-2022, 02:31 PM
Absolutely!! The more people that do, the more likely it can happen.
Also ask on the LogicProHelp forum. Can usually rally a fair bit of support there, where others will also send Apple feature requests.
Matt McKenzie-Smith
mattrixx.net
Old 11-15-2022, 06:51 PM
OK thanks. If you get a chance to check that out, would appreciate it!
Try the modes Eddie mentioned "Are these knob controls? As well as the 5 normal and 5 shifted function buttons(EQ/DYN/PAN etc.) there are more if you press and hold these buttons, the LED will flash after you have held it long enough. They could be in those."
Avid Control Soft Keys and Pro Tools Dock Settings for Logic Pro X worldareaecho Avid S1, S3, Dock and Control App 36 02-08-2023 07:19 AM
Avid Dock with Logic Pro an Apple M1 Clore Avid S1, S3, Dock and Control App 7 09-29-2021 07:23 PM
What Dock Wheel Functions for Logic Pro X? sjgam Avid S1, S3, Dock and Control App 6 09-05-2021 12:26 AM
S1, Dock, Avid Control Logic Pro X bug Orchook Avid S1, S3, Dock and Control App 20 07-08-2021 03:09 PM
Avid S3 + Pro Tools Dock latency with Logic Pro X Angel Xerran Avid S1, S3, Dock and Control App 0 09-11-2019 10:09 AM
