Old 03-01-2021, 06:29 AM
[email protected] sleshnyc@gmail.com is offline
Default Can't record tracks in a routing folder due to latency
Anyone else have this issue? If I have a track in a routing folder, and then want to record to it, the latency is so bad I have to pull it out of the routing folder and send it straight to the master buss. I have this same issue with plugins on the master buss. I have to remove them, especially things like L1.
And yes, I have delay compensation on. Pro tools 2020.12 on a mac 10.14.6 using hdx.
Old 03-01-2021, 07:51 AM
Default Re: Can't record tracks in a routing folder due to latency
Take a look at the delay compensation view in the mix window, that will tell you exactly what's going on with your routing folder - the routing folder is just like an aux and if you're routing a record track through it it will still be compensating for latency of other tracks.
Instantiating high latency plugins on a master fader while recording is never a good idea.
http://www.richbreen.com
Old 03-01-2021, 08:22 AM
TOM@METRO's Avatar
Right... Plug-ins on a Master track are not delay compensated.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-01-2021, 08:32 AM
Its not whether Delay Comp is enabled, its how much delay needs to be compensated for(showing the numbers is the way to find out). Remember that Delay Comp works by finding the track with the highest latency and then making all other tracks LATER to match(so it doesn't make latency disappear).
As said, latency on a MASTER track is not compensated for(because it doesn't need to be under normal circumstances). Some like to work with mastering plugins in place(a bad idea IMHO), and since many of those have huge latency, the solution is to make them inactive while recording. This same solution applies to plugins on AUDIO and AUX/FOLDER tracks too.
There is also a known bug when routing thru multiple AUX tracks where the built-up latency may not be compensated for properly(that may or may not apply in this case, but it is something to be aware of and listen for)
Old 03-01-2021, 12:17 PM
Thanks, yes i'm aware of the master buss thing. I get rid of them before i do any recording. But I have NO plugins on my folder and the delay is massive. It's just being routed. Very strange, bc if I just route to a regular aux there's no issues at all. It's ONLY through a routed folder.
Old 03-01-2021, 01:28 PM
Hmmm, that gets a bit more interesting. Check for any send that doesn't actually go anywhere. That can cause over 1900 samples of bogus Delay Comp(making rows of sends inactive and testing will reveal this) as soon as you put a track in record-ready. Show Delay Comp and watch the numbers while you click record buttons and see if the numbers suddenly jump.
Knowing that^^^ might also spur some deeper testing because, while I never record with AUDIO tracks that route thru AUX tracks(Routing Folders would act the same), it might actually be possible that there are other ways to confuse PT. I guess the temp solution is to route recording tracks directly to the main outs(I know...I PITA when all you want to do is lay down some audio).
Old 03-02-2021, 07:32 AM
On your routing folder are there other tracks in that folder with high-latency plugs on them?
As a troubleshooting step: What about if the track in question is the *only* track in the routing folder?
Old 03-02-2021, 04:05 PM
"The latency is so bad"... yes but you should measure exactly what the latency is in # samples (and tell us the sample rate) and that often gives a clue to the source.
"... is just an aux..." ... and we know how aux's can add huge latency with high latency domain buffering on native systems. So is this behaving like that... are there native plugins in this signal path? Is it possible this is in disk playback/high latency domain buffer?... so 2K or whatever hardware buffer latency (depends on the sample rate... which you don't tell us) plus possibly some plugin delay?
Old 03-03-2021, 06:51 AM
A (full res) screenshot of the mix window with ADC view enabled will probably help
Old 03-03-2021, 07:08 AM
DontLetMeDrown DontLetMeDrown is offline
Sounds like you have no plugins in the routing path? (Beginning to end, not just the one routing folder)
I suspect the same as albee. More specifically- make sure the armed track doesn't have a send going to an inactive track or buss or output. I record exclusively to tracks that are inside routing folders but I'm also meticulous about only using 0 latency plugins during tracking.
Serious Routing Folder Bug! DrewHarrison Pro Tools 2020 8 07-21-2021 02:26 PM
Routing folder+VCA mgoorevich Post - Surround - Video 12 09-30-2020 03:45 PM
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus XJENSEN Pro Tools 2020 7 04-24-2020 07:29 AM
When routing an aux buss to audio to record monitoring latency Tristos Pro Tools 12 2 10-21-2017 06:36 AM
Latency when record multiple tracks! audioplace estudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2009 05:11 AM
