Old 08-26-2017, 02:37 AM
aljaz aljaz is offline
Default Re: Ephonix MC Mix (v1) and Eucontrol 3.6.1
Originally Posted by EddieJones View Post
Please describe the issue more. Do you see the Mix in the surfaces list ? is EUCON checked in PT prefs ? Is the network interface selected correctly ?
Yes, I see the MIX surface list. EUCON is checked in PT pref.
Thanks.
Old 08-26-2017, 08:38 AM
EddieJones's Avatar
On the right side ? What do the OLED's show on the Mix ? Is the WS checked on the Workstation tab ?
Old 08-27-2017, 12:26 AM
Yes, on the right side Mix is checked with green tick.
Old 08-27-2017, 09:00 AM
EddieJones's Avatar
I meant on the Workstation tab...is that checked too.
Please tell me what is displayed on the Mix's OLED screens ?
Old 08-27-2017, 09:56 PM
Ok. Currently away from studio. I will check on Thursday. Speak soon.
Thanx.
  #16
Old 08-31-2017, 08:34 AM
Thanx.
On the MIX OLED screens I see only green dotted rectangulars above each channel and nothing else.
  #17
Old 08-31-2017, 09:08 AM
EddieJones's Avatar
If you disconnect the Mix on the surfaces tab do these go away? if so it means EuControl is seeing the Mix and the issue is on the WS side. If you definitely have the WS checked on that tab and the EUCON pref checked in peripherals in PT then it should work.
  #18
Old 08-31-2017, 10:41 AM
If I disconnect the MIX in the surfaces then it goes away like it is expected. It means there is communication between PC and Mix. In PT 10 (32bit) in the peripherals Eucon is checked but MIX is not responding. I do have also MC control which I plugged and it is the same issue. Is there a root cause becasue PT 10 (version 10.3.9) is operating in 32 bit but newest driver is for 64 bit ?
If I connect MIX to other DAW- 64 bit then MIX is operating normally.
  #19
Old 08-31-2017, 01:49 PM
EddieJones's Avatar
if other DAW's are working fine then the issue has to be with PT. Maybe try uninstalling PT and reinstalling.
  #20
Old 09-02-2017, 11:40 AM
I will do so asap.
Keep you posted about result. For me it is not usual because with an old driver and firmware everything was working perfect.
Thanks.
Eucontrol & Cpu jky Artist Series 2 10-30-2016 09:38 AM
EuControl 3.4 mbryan67 Avid S1, S3, Dock and Control App 5 05-27-2016 02:23 PM
Where to get Eucontrol 3.2.1? dumbeat Avid S1, S3, Dock and Control App 5 04-12-2015 03:08 PM
Eucontrol wgouldsby General Discussion 3 02-25-2013 01:36 PM
Eucontrol 2.6.2 out robertg Artist Series 22 11-07-2011 12:11 PM
