Old 07-17-2017, 02:41 AM
Tomess Tomess is offline
Default Ephonix MC Mix (v1) and Eucontrol 3.6.1
Hello!
I'm aware, that the old Ephonix MC Mix controllers are not officially supported anymore, but i've found no word about an incompatibility to Eucontrol 3.6.1 and related firmware update anywhere in the forums or the official side from AVID.
But i'm afraid, that when i update the driver and the firmware, it will turn my 2000€ worth controllers into two expensive doorstoppers...
has anyone tried to update and can verify that this works or not?
I'm on Win7 64 bit, My DAW is Cubase Pro 9 64 Bit and my installed eucontrol software version is 3.3.2.
Cheers, Tomess
Old 07-17-2017, 04:35 AM
Manu101 Manu101 is offline
Default Re: Ephonix MC Mix (v1) and Eucontrol 3.6.1
I'm using 2x Euphonix MC Mix and a Euphonix MC transport with no problem. Eucon 3.6.1, PT HD 12.8, OSX 10.10.5
Manu
PT Ultimate - Mac Studio M1 Max - Monterey - RME Fireface UFX II - 2x S1, 1x Dock with an iPad 7th gen - Genelec 8330 5.1 setup
Old 07-17-2017, 06:05 AM
ALSTUDIOS ALSTUDIOS is offline
Hi
I'm as well on Win7/64bit and Cubase 9.0.20 and use an Euphonix MC Mix and an AVID Artist Control.
Works fine, besides the font on the touchscreen of the artist control.
Seems to be bigger now than before. Had to modify some of the own created softkeys-naming.
Cheers
ALSTUDIOS REGENSDORF SWITZERLAND
[email protected]
https://sites.google.com/site/alrecordingstudio/
1pc AVID Artist Control and 1pc Euphonix MC Mix
Win11 64Bit, Cubase Pro 12.0.52
Old 07-17-2017, 11:06 PM
Ok, nice! Thanks for clearing that up for me!
Old 07-18-2017, 09:29 AM
EddieJones's Avatar
Hardware is not supported but Software is still the same as any version of Mix.
Old 07-19-2017, 12:48 AM
Hey EddiJones,
Sorry if i have to ask again, but i'm not sure if i get this right: does that mean, that the hardware is still compatible with the soft- and firmware, but if there is a hardwareproblem (e.g. broken fader) there is no support anymore?
Cheeres, Tomess
Old 07-19-2017, 06:37 AM
EddieJones's Avatar
Yes you are correct, although you may even be able to get the hardware fixed for a cost as much is the same.
Old 07-19-2017, 07:10 AM
Great! Thanks again Eddie
Old 08-19-2017, 06:38 AM
aljaz aljaz is offline
Hello, I do have issues on PC WIN 7 / 64 bit , PT 10. Since I did an update of latest driver and firmware, MC mix stop responding.
Any hints or I shall do downgrade of driver and firmware to 2.6.2 ?
Thanks.
Old 08-23-2017, 07:53 PM
EddieJones's Avatar
Thanks.
Please describe the issue more. Do you see the Mix in the surfaces list ? is EUCON checked in PT prefs ? Is the network interface selected correctly ?
Eucontrol & Cpu jky Artist Series 2 10-30-2016 09:38 AM
EuControl 3.4 mbryan67 Avid S1, S3, Dock and Control App 5 05-27-2016 02:23 PM
Where to get Eucontrol 3.2.1? dumbeat Avid S1, S3, Dock and Control App 5 04-12-2015 03:08 PM
Eucontrol wgouldsby General Discussion 3 02-25-2013 01:36 PM
Eucontrol 2.6.2 out robertg Artist Series 22 11-07-2011 12:11 PM
