Old 02-10-2018, 11:31 AM
Default Re: HD I/O - HD Omni Impedance numbers
Originally Posted by SergUS View Post
... If from the output of Avid 16x16 analog to apply to the input of 192 I / O then the result is also excellent. If on the contrary, the result is depressing, which indicates the problems of the input channels at 16x16. the same problem with Avid Omni. I'm curious about this on all new avid interfaces?
interesting - at a glance it appears that Avid has changed their A/Ds and it's not for the better (at least in terms of filter ring). This should probably be in a separate thread - it's also difficult to see exactly what's going on from the low-res screenshots; higher res pictures would help.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-10-2018, 01:11 PM
BScout BScout is offline
Hello!
Tell me what is Avid 16x16 analog and HD OMNI with HD Native Thunderbolt. If you feed a rectangular signal from any output to any input at a sampling frequency of 44100 or 48000, will you still have the signal without visible changes or be distorted? If I switch to 96000, the signal remains almost unchanged!
I tried to do these manipulations with I / O 192 and this interface produces almost ideal rectangle shapes at any sampling frequencies. If from the output of Avid 16x16 analog to apply to the input of 192 I / O then the result is also excellent. If on the contrary, the result is depressing, which indicates the problems of the input channels at 16x16. the same problem with Avid Omni. I'm curious about this on all new avid interfaces?
Love to see your pictures but they are too tiny to be useful to see what has been done. Also, for conformity, vs using the signal generator plugin, I suggest using an audio file (even if that audio file is created by the signal generator.)
Old 02-10-2018, 01:17 PM
If anyone was wondering:
The Avid I/O output impedance of +4 is 50 Ohms
The MTRX output impedance is <30 Ohms
Old 02-10-2018, 09:35 PM
SergUS SergUS is offline
Hi.
Thank you for your interest. Here is a link to the screenshots of a larger resolution.
https://cloud.mail.ru/public/stZs/hGMNavm5V
Old 02-10-2018, 09:42 PM
Hi.
HD Omni, headphone impedance Exodius Pro Tools HDX & HD Native Systems (Mac) 16 08-09-2016 09:13 AM
which is best impedance for headphones? rob wots Eleven Rack 21 06-07-2014 05:28 PM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
OMNI preamp impedance? Mr.Scarbee Pro Tools HDX & HD Native Systems (Mac) 0 08-09-2011 04:19 AM
