Old 01-09-2018, 03:05 PM
chrisjco chrisjco is offline
Default Midi Beat Clock issue
Using midi beat clock in protools 12.5 to sync with a Korg minilogue via usb or midi the clock is skipping or adding time around the 5th beat.
Have proven it’s a pt issue as no problems in logic via same setting and cables.
I’ve tried it with and without delay compensation for midi devices so I know it’s not that.
I’ve looked at and adjusted the offset for the beat clock for the minilogue output and seen/heard no change.
Previous sync with other synths and earlier pt versions have been fine.
Any pointers much appreciated
Old 01-11-2018, 10:33 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Midi Beat Clock issue
Originally Posted by chrisjco View Post
Just a thought, but does the Korg have a setting to choose what DAW you're using? I know on my Yamaha Motif XS I have an option to set the DAW. While PT isn't one of the options, I found that it works best with the Sonar option selected. If you have such an option, you might try changing that. Each DAW might work a bit differently where MIDI clock data is concerned, and the DAW selections might compensate for that.
Just an thought...
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
MPC 3000 and PT 9 beat clock issue michaelc22 macOS 0 10-03-2011 10:24 PM
MIDI beat clock latency issue!! overseasmusician Pro Tools M-Powered (Win) 0 11-04-2007 04:57 PM
MIDI BEAT CLOCK ISSUE atomsmasher Pro Tools TDM Systems (Mac) 1 12-04-2006 05:56 PM
Triton...is MIDI Clock difrnt than MIDI Beat Clock BookSix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2006 12:24 AM
MPC 2000/MIDI Beat Clock issue djwilmer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-22-2003 06:27 AM
