Old 12-11-2017, 11:12 AM
seungkeeya seungkeeya is offline
Default C|24 Stereo Speaker set up!
Hi, I am new to the forum.
Always have been helped out tremendously by tips and insights that you guys are throwing. Didnt get to thank you until now!
I recently purchases a C|24 unit.
We as a start out sound/media company, wanted to utilize C24 as a main contol surface.
As I was learning as I go, I was encountered a very novice question.
When connecting stereo monitor speaker L and R to C24, using DB25 to XLRfem, XLRm coming out of my speakers to 1-3 of DB25, right?
For now we only use two monitor speakers, so if I buy a cable with 6 more XLRfem, I thought it might just stat there and not being used.
There are two Alt-Out line output so I attempt d to plug speakers directly into those, but I couldn’t get any sound, however I couldnt think of going into I/O in my PT and configure.
Long story short, if i were to connect two monitor speakers to main output of c24, buying a DB25 to XLRfem would be the best solution?
Many thanks in advance.
I have been searching for a long period, couldn’t seem to find the clear method..
Would appreciate it a lot!!
Old 12-11-2017, 11:45 AM
Southsidemusic's Avatar
Default Re: C|24 Stereo Speaker set up!
Welcome to the Community
Best to check the reference guide/manual here:
http://akmedia.digidesign.com/suppor...uide_41362.pdf
If you have a 8 connection db25 snake you don't need to use more than two of the outs as the rest will be there for future connections.
Let us know if you get stuck again
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-11-2017, 12:21 PM
Thank you very much for your input.
Yeah i was reading manuals many times before I got the c24 just to jump on ot and do the homwork.
So just get db cable to xlr fem and use only two for stereo, leave the reat for future use right? Got it.
Thanks. I am sure ill research&ask bunch of questions!
Old 12-11-2017, 04:58 PM
Actually, I came across this thought,
I am using Apollo 8P.
Is it rightful to connect the main out 1-2 from Apollo into C24's Monitor-Input as stereo? Would I be able to get a full monitor control on c24??
Old 12-11-2017, 06:36 PM
s.d. finley s.d. finley is offline
do this, main outputs from Apollo 1-2 should go into the monitor C/24 DB25 inputs for left and right. From the C/24 DB25 output 1 should go to the Left monitor and DB25 output 3 should go to the right monitor. C/24 is set up for surround sound so the outputs are different. Try it, it works for me.
sdf
www.sugarhillstudios713.com
Old 12-11-2017, 08:09 PM
Thank you!! This sounds like the way.
Just to confirm then, should i get db25 to female or male end??
I’m using genelec 8020 pair so i use xlr male to TRS jack. (TRS out from interface to Xlr going into monitospeakers)
Jist want to make purchase right and future-proof.
Thank again for your input!
Old 12-11-2017, 11:36 PM
Apollo is TRS so DB25 to TRS for that snake and if the Genelecs are XLR then yes DB25 to XLR and should be male for that snake. The DB side of the snake will normally always be male. Glad to be of help!
sdf
Center Speaker Output playback on Left & Right speaker Ayem Ismail Pro Tools 11 2 01-08-2017 11:05 AM
Aggregate I/O Built-in Speaker causing speaker to crack and pop andrewkeithly macOS 2 01-27-2012 11:10 AM
one speaker sounds in stereo fender3 Tips & Tricks 1 12-27-2006 08:19 AM
one speaker sounds in stereo fender3 Tips & Tricks 0 12-24-2006 06:32 AM
Home stereo speaker monitoring 6969 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-10-2002 01:40 PM
