Old 12-22-2011, 11:58 PM
DJ Hellfire DJ Hellfire is offline
Angry Session layout not being remembered after closing/reopening a session/Pro Tools!
What's up. I'm noticing a small issue, not a big deal, but just really annoying in PT 10. When I reopen a session, Pro Tools isn't keeping my window configuration. Mainly being, for some reason, every time I open a session, the regions/clips pane is open. And I never keep the regions pane open while working. It's always closed unless I need to remove/delete/export a clip. But for some reason it's always open when I open a session, and usually only in the mix window.
Also, for some weird reason, most times when I create a blank session, there's a click track already made. What's up with that?
Then there's other times when I'll reopen a session and some of my busses are renamed and/or some audio tracks are routed incorrectly to a different bus than I had them set at originally. And every time I close and reopen the session, I have to keep reassigning the audio track to the correct bus.
Just a bunch of weirdness going on! Anyone else?
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 12-23-2011, 12:05 AM
Default Re: Session layout not being remembered after closing/reopening a session/Pro Tools!
Check your prefs.. if you don't have it set to do that... trash them and reset all your prefs.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
PT 11.02 freezing after closing a session and opening new session asaffulks Pro Tools HDX & HD Native Systems (Win) 2 12-17-2013 01:49 PM
Closing Session Shuts Down Pro Tools ryanwilsonfive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 10-18-2007 11:00 AM
Crashes when closing session Pro tools 7.0 Drive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-07-2006 01:34 AM
Pro Tools v5.1.3 Crash When Closing Session Chief Technician Pro Tools TDM Systems (Mac) 22 09-21-2002 03:17 PM
pro tools app. crashes when closing session Blake Henderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-27-2001 04:22 PM
