Old 06-14-2018, 06:44 AM
reichman's Avatar
reichman reichman is online now
Default Video Format: Encoded Size vs. Display Size?
I have a video from a client:
DNxHD
bit rate 100 Mbit/s
interlaced
encoded size 1440 x 1080
display size 1920 x 1080
It doesn't perform well. A little choppy, AVE reads 160% CPU usage. Converted the video with Media Encoder to one of my DNx presets to this:
DNxHD
bit rate 147 Mbit/s
progressive
encoded size 1920 x 1080
And now AVE is using 80% CPU. I've run into this "encoded size" issue before. What's happening? Or is it the interlacing that's causing the AVE problem?
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
RHUMBA
www.rhumba.pro
Old 06-14-2018, 12:36 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
Default Re: Video Format: Encoded Size vs. Display Size?
To my simplistic understanding the issue is the scaling required to display the pixels correctly.
The 1920 by 1080 has a 1 to 1 pixel sizing - no display scaling.
The 1440 by 1080 has a 1 to 1.2x pixel sizing -intense display processing.
Andrew
Old 06-15-2018, 01:20 AM
papalou papalou is offline
Andrew
You're 100% right, except for the pixel aspect ratio, which is 1.33 and not 1.2.
Old 06-15-2018, 08:08 AM
reichman's Avatar
After some more testing, I found that I could run AVE all day at 40% CPU usage by going 1280 x 720p. For most programs, that looks good enough in a medium-sized post room. Size matters, scaling matters. Not sure about interlacing. I'll save that test for next time.
Nathaniel Reichman
RHUMBA
www.rhumba.pro
HTML code is On
S3 Display font size problem hj0102 Pro Tools | S3 8 08-06-2016 08:39 AM
How to increase track display size? HaydenF Pro Tools 12 4 04-08-2016 03:25 PM
Format Staff Size swingaroux Avid Scorch (iOS) Forum 4 08-04-2015 09:10 PM
Increasing display font size MboxToo Tips & Tricks 1 05-06-2009 06:17 PM
Which Size Apple Display Does PT Look Best On? decibel Pro Tools TDM Systems (Mac) 23 12-17-2003 06:54 PM
