help with 002/PTLE 7.4 upgrade
Hi all
I have just upgraded from 001 to 002, and PTLE 6.4 to 7.4. (I had happily been using the 001/PT6.4 for over 2 years.) The Install/upgrade went ok, although the PC did have some some trouble finding the hardware. Now I find that on reboot, everything works fine, but if I exit PT 7.4 I cannot restart it. It says it cannot find the hardware and I have to reboot. I have a new p35C gigabyte dual core motherboard with 2 firewire ports. One port is plugged into an external firewire 500GB hard-drive (drive letter is I:) and the other is plugged into the 002. They are on separate firewire cables, which as far as I know should work fine. If I restart PT 7.4 most times it says cannot find hardware AND the I: drive disappears. Other times it just doesnt come up on the screen - I can see it in processes in Task Manager but is using only 22MB memory instead of the usual 120MB. Seems that there is some kind of confusion between the firewire ports ? I'd be the first to admit that I may have missed something fundamental but if anyone can help out I would very much appreciate some advice. Thanks very much in advance. I will do SI Sandra config extract as soon as I can in case it is needed for this thread. |
Re: help with 002/PTLE 7.4 upgrade
I'm not convinced that your mobo is compatible but, some things to try anyway: install/run the dual core hotfix and update the PACE drivers. Also, try running one firewire cable to the hard drive and run from there to the 002(I don't know why it would matter but it won't hurt to try it).
Thanks heaps for your reply/help
heres the pc wizard summary: <<< System Summary >>> > Mainboard : Gigabyte P35-DS3P > Chipset : Intel P31/P35 > Processor : Intel Core 2 Duo E8200 @ 2666 MHz > Physical Memory : 2048 MB (2 x 1024 DDR2-SDRAM ) > Video Card : SAPPHIRE Radeon X1550 Series > Hard Disk : Disk (200 GB) > Hard Disk : Maxtor USB (164 GB) > Hard Disk : Maxtor USB (251 GB) > Hard Disk : SAMSUNG USB (200 GB) > Hard Disk : Maxtor IEEE 1394 (500 GB) > DVD-Rom Drive : SONY DVD-ROM DDU1615 > DVD-Rom Drive : SONY DVD RW DW-D26A > Monitor Type : Dell Computer DELL E207WFP - 20 inches X 2 > Network Card : Realtek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC > Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 2 > DirectX : Version 9.0c (November 2006) Can u tell me if anything in the above looks incompatible ? if all ok I will proceed with your earlier suggestions... thanks again |
Oh and one more thing: I dont think I can try your second suggestion (daisychaining) as the Maxtor external 1394 500GB drive case only has one 400mb/s firewire port.
It does however have 2 X 800mb/s ports - I could daisy chain if I upgrade the pc to 800 mb/s but then I believe the 002R doesnt have 800mb/s capability ? |
Cannot upgrade to PTLE 8, please help | Boompole | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-26-2012 11:45 AM |
Upgrade to PTLE 7.4 - Need help! | Mike Borok | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-13-2008 07:41 PM |
PTLE Upgrade 7.3 > 7.4 | Orange Worker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-27-2007 04:38 PM |
PTLE no 5.3.1 upgrade...? | ckerian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-22-2002 12:56 AM |
PTLE 5.1 Upgrade: When and How? | ToucanSam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-01-2001 03:17 PM |
