Re: MIDI timing / recording delays with Delay Compensation
Well I did that little experiment and it works.
Actually used Omnisphere in 10.3.6 for the test. 1) Created 8 stereo instrument tracks. 2) Loaded up omnisphere onto the first instrument track. 3) Set up 8 different sounds in omnisphere channels 1-8, and set each sound in the omnisphere mixer to go via a different output (A to H) 4) Set the MIDI output of each of the 8 instrument tracks to omnisphere 1-8 5) Left the audio input of the track with omnisphere on it untocuhed (says no input) 6) Set the audio inputs of the other 7 instrument tracks to omnisphere Stereo B to H Then, whichever track I have record armed sends midi to the relevant omnisphere channel, and the audio comes out of the relevant instrument track too. Recorded midi data onto each track and played back. MIDI is routed correctly and audio comes out correctly. So, no need to use a combination of MIDI and Aux tracks for the extra parts of a multi-timbral VI. Just use Instrument tracks and set up the MIDI outputs and audio inputs appropriately. I feel silly that I didn't try that sooner.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
Thanks for that, Nigel. That is useful to know about.
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
Nigel, your method is mentioned on Pro Tools Expert today.
http://www.pro-tools-expert.com/home...ps-part-5.html
Yeah, I noticed ...... what a co-incidence ;-)
I was that impressed that I posted a coment on that community tip, including links to my posts in this thread Thanks for the head's up though
I haven't the time nor the patience to read this entire thread. I understand you have found a workaround, but to add my 2 cents. It is a bug in Pro Tools existing in and up to the latest 32bit ver (10.3.9) which entails as follows:
Using a midi track to trigger an instrument (not directly sequencing on the instruments track itself). The idiots who code for avid have somehow managed to add in the latency of the master buss to the chain. Ergo the latency of a midi track to the actual instrument track equals buffer samples (1024,2048,etc) plus ALL of the latency of your plugins on the MASTER buss plus 328 samples just for fun. This is what AVID call ADC! so you can use the "global midi playback offset" feature (preferences -> MIDI) to counteract your buffer latency, but don't track with plugins on your master buss until AVID pull their finger out....or use the instrument track directly... love, peace, and have a nice life! |
#16
This midi > instrument track bug is really annoying. I believe AUX have automatic delay comp, is this the same case for instrument tracks?
#17
#18
I am having this issue too. And the wierd thing is, it just started happening as I'm touching up final mixes on a project.
Maddening. And still no real solution.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002) |
#19
Anything that takes me out of creative mode is worthy of the strongest of criticisms.
#20
Come one now, you're talking to the king of tangential stabs at Avid (because, yes, they have their issues), but even I thought his 'I can't be bothered by this thread, but I'll post something unrelated anyway' was hilariously forced.
PT 10 and Delay Compensation while recording | tekis | Pro Tools 10 | 7 | 03-10-2014 07:09 PM |
Recording and delay compensation | Paolino_o | Pro Tools TDM Systems (Mac) | 2 | 04-13-2011 12:48 PM |
Delay Compensation Timing problems with RTAS plugs | Kourquie | Pro Tools TDM Systems (Mac) | 2 | 07-22-2007 03:50 AM |
MIDI Timing, Buffer Delays etc : What We All Should Know | Zep Dude | Pro Tools TDM Systems (Mac) | 3 | 05-26-2007 05:24 AM |
Rtas / midi timing compensation | bluesna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-27-2006 07:00 PM |
