Old 11-08-2011, 12:27 PM
b-tastic b-tastic is offline
Exclamation Ugraded system now PT 5.3.1 (digi001)will not play
I have had this original system for about 8 yrs now.
With all my plug-ins it was just not enugh for the P4 proceser + 2Gb ram.
Now, I have upgraded to a "new" system with an MSI mother board, i5 Intel proseser, 4GB ram but still running XP pro with SP3. and 2 seperate TB of storage (1tb for sys and 1tb recording)
I have move the Digi card in differant PCI slots and returning back to the loest numbered place, Uninstalled and re-installed PT a couple of time to make sure...Loads every time no complants and fast.
But...When I press play(space bar) arrow lights up nothing happens meter does not change any numbers and can press stop(space bar) and still responds and blue sqaure lights up.
I want to upgrade but I really need to finish this album first.
Thanks for all your help,
Bill
Old 11-08-2011, 01:11 PM
sunburst79 sunburst79 is offline
Default Re: Ugraded system now PT 5.3.1 (digi001)will not play
I suspect that you need to upgrade to 6.4 cs9 and the 6.4cs6 Plugin updater.
Depending on your i5 chipset it may not support natively. What effect that would have on a very old PCI card like the 001 I can't say.
I have a 001 running on a simple Core 2 Duo and its fine with XP SP3.
Your computer may to new. Your version of Pro Tools is definitely too old.
Also update the PACE drivers to the current version. You should also have Quicktime installed
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 11-09-2011, 12:20 PM
Thanks, for the quick respones. OB1
But, I did have a problem loading untill I updated my ILok/PACE.
Now I can load PT properly.
I also Updated my QuickTime to 7.
But, Still Loads with no problem but does not play.
Could it be somthing to so with Timeing?
PT 6.4/Digi001 Won't Play niespodj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-08-2011 12:32 PM
i finally ugraded to Mac Pro and PTLE 8. DV Toolkit 2 question. 16yearsjeff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-19-2010 10:23 PM
How do I sync my Digi001 system to my Digi 003 System? bethusghark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-05-2009 08:00 AM
Ugraded to cs4, now ESC doesn't work on C24! a2zproductions Pro Tools TDM Systems (Mac) 0 08-02-2007 09:02 AM
HELP !! Cannot get Rebirth to play through Digi001 dw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-24-2000 06:35 PM
