Which MBox
Hi I'm running a MBP (2.66ghz Intel Core Duo // 4GB 1067 MHz). System: 10.7.2
I had an MBox 1 running ProTools LE 7.4 - now redundant. I used this for vocal recording and mixing at home (multiple channels are a must). What is the cheapest but most effective replacement I can get? I'm looking for parity, basically. Thanks |
Re: Which MBox
Since you mentioned "multiple channels" I would suggest the new Mbox 3 Pro bundled with PT9, which gives you a free upgrade to 10.
You may already know this, but you won't be able to use 7.4 on OS Lion. |
Re: Which MBox
Whatever you do; do NOT get the mbox3 mini.
Everything is great except for one big thing: no mono button! If you stick your mic in channel 1, and monitor the input you only get the mic in the left side. And whatever you put in channel 2 will always be in the right side. And since it's USB you get at last 128 samples latency if you want to monitor via pt to overcome the left/right issue. |
+1 on not mini. The pres in the Pro & the mbox are better.
Both have some low mic gain issues but unless you are doing chamber music with low output mics, you won't have a problem.
Main Workstation: Pro Tools 2023.12.1, Windows 11, HP Z4 Xeon 8 core W2145, 64 GB DDR4, Omni, Artist Mix, Sync X, Eleven R(2 of them), UAD 2 PCIe card |
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available | Avid | Technical Alerts | 0 | 10-30-2012 04:24 PM |
Mbox mix knob always plays a drum track,Mbox 2 and Pro-tools LE 8: | Haezel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-20-2011 02:58 AM |
Digi Tech Suppport? Pfft!!! Mbox/Mbox academic Questions | WestPhillySoulzition | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-17-2008 01:03 PM |
Mbox 2 Pro vs Mbox latency - Mbox 2 Mini pro? | marcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-28-2006 08:18 PM |
Mbox - Routing the computers audio through the mbox ie. CD Rom, system sounds | brownmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-30-2003 03:22 PM |
