Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 07-12-2018, 02:27 PM
GreenWire GreenWire is offline
Default Controlling PT main outputs with MacBook volume controls
Hey folks, I'm having some issues using Pro Tools Ultimate 2018.4 on my MacBook Pro. Audio from the PT main outs is coming out my laptop speakers/headphone jack (I'm not using an interface), but the laptop volume controls aren't having an effect, so I'm getting blasted. Seems like something simple and obvious that I'm missing, any suggestions?
Thanks.
Old 07-12-2018, 03:52 PM
Sardi Sardi is offline
Sounds like you might have ‘Use all F1, F2, etc. keys as standard function keys’ enabled in System Preferences. Most people do when using PT so that the function keys can be used to access PT functions.
If you do, hold down the Fn key at the same time as adjusting the volume and it will override the above setting. Will work for brightness etc. as well.
Old 07-12-2018, 04:05 PM
Default Re: Controlling PT main outputs with MacBook volume controls
Hey Sardi, thanks for the reply. That doesn't seem to be the answer, however, the volume/mute keys work fine for all the other Mac audio, and I don't have ‘Use all F1, F2, etc. keys as standard function keys’ enabled in System Preferences.
Main Output knob not controlling left speaker (FT Duo) spicyhamster FireWire and USB Audio Interfaces (Win) 1 02-16-2017 12:28 AM
Amp outputs same level as Main outputs? DonaldR Eleven Rack 0 02-07-2013 01:50 PM
Nothing coming out of 11R Main Outputs adjectives Eleven Rack 0 05-07-2012 01:01 PM
Controlling main Pro tools rig from remote PC? Aquitus Pro Tools TDM Systems (Win) 5 10-30-2010 08:03 PM
