Old 12-21-2012, 03:59 PM
RCN RCN is offline
Default Uninstall PT Before installing 10.3.3
Hey guys Avid recommends a full uninstall before updating to 10.3.3, I'm on 10.2, if I uninstall this will that work or do I need 10.0? Thanks
Rob
Fattrackstudio.com Pro Tools 10.2 HD4, Mac Pro, Magma pe6r4-1, Apogee AD16x, Digi 192, Digi 96
Old 12-21-2012, 04:22 PM
gives's Avatar
gives gives is offline
Default Re: Uninstall PT Before installing 10.3.3
Rob
I am pretty sure that 10.2 will work as it was a full install I think, but you might need to check.
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2019.5 Ultimate HD Native Thunderbolt Avid HD IO
Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Sierra 10.12.6, Digital Performer 9.5
Old 12-21-2012, 04:26 PM
gives's Avatar
Rob
What OS are you running.. ?
I read some thing in the Mountain Lion OS updating to PT 10.3.3, that they were recommending you do a "clean install", which did not make sense to me, since I do not thing that is possible with the OS update from Lion to Mountain Lion.
UNLESS they are just talking about what you are saying here? Just wondering.
G
Old 12-22-2012, 09:33 AM
RCN RCN is offline
I'm on 10.6.8, I think you're right that 10.2 is a FULL INSTALL... Can anybody confirm this?
Old 12-22-2012, 10:52 AM
jryser's Avatar
jryser jryser is offline
Default
Yes it is.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 12-22-2012, 04:21 PM
gives's Avatar
Here is from the Installation notes page.. I dug a bit and found it.
Installation
Pro Tools 10.3.3 is a full installer. Avid recommends uninstalling your current version prior to installing 10.3.3 (reinstall the Drivers for your interface after a Clean Uninstall).
Pro Tools 10.x uses a single installer for both Pro Tools and Pro Tools HD. The installation is the same for both; only the authorization is different.
Old 12-23-2012, 06:41 PM
Larold Larold is offline
I just did this on Mountain Lion. I uninstalled 10.2 (using the safe mode...the recommended option). Then I installed 10.3.3, and no problems. There were some preferences, especially IO things I had to re-adjust, but it seems to be running smooth as silk.
Old 12-23-2012, 06:44 PM
You do realize that they are talking about a full clean install of ProTools, not the OS, right?
Old 12-23-2012, 10:27 PM
RCN RCN is offline
Yes, thanks all....
Old 12-28-2012, 05:06 PM
studiojimi's Avatar
studiojimi studiojimi is offline
i did it....it works seeming well
no apparent glitches
i'm gonna clone my drive now
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
what uninstall before PT 10 installing flautista Pro Tools 10 5 12-11-2011 06:12 AM
Uninstall LE 8 before Installing 9?? JCK43232 macOS 2 05-17-2011 03:07 PM
Uninstall 8.04 before installing PT9? xpandnz Windows 1 01-31-2011 11:54 PM
Uninstall 7.3 before Installing 7.4? GuyPicks Pro Tools TDM Systems (Mac) 2 01-11-2008 06:42 PM
Uninstall 6.4 before installing 6.7? neonknight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 11-10-2004 01:42 PM
