Old 09-29-2006, 10:10 AM
bassclar782 bassclar782 is offline
Default Input\'s greyed out on Mbox Input section...
Hello all,
I recently purchased an Mbox 2 and am having toruble recording on my laptop. The input selection for any channel I create are greyed out, and I can't seem to figure out why. I'm running an Mbox 2 with a PowerMac G4 laptop, 1GB of ram and recording to an external hard drive. I'm running version 6.8.1 with Panther for OSX. I've downloaded the firmware update for the power issue, as well as the apple download for powerbook batteries. Any suggestion would be helpful, I'm about to go crazy with the issue.
thanks in advance for any help anyone can provide. I found this topic in a different post, but the topic wouldn't open up. Thanks for everything.
Peace.
Old 09-29-2006, 10:47 AM
Kryst Kryst is offline
Default Re: Input\'s greyed out on Mbox Input section...
Try plugging the mbox into other USB Ports in your Mac. Certain USB Ports do not have enough power to run the mboxs
Kryst
Old 09-29-2006, 12:21 PM
Also, double-check your I/O setup. Maybe reset to default.
Old 09-29-2006, 01:08 PM
I've tried to plug it into the other USB port, and I've checked the input section on Input/Output selestion. The input sections is on default and shows everything as being available. The other USB port does the same thing.
Thanks for the help though. If anyone else has any suggestions, I would be very greatful. Thanks.
Peace.
Old 09-29-2006, 09:02 PM
jre3132 jre3132 is offline
this may be basic, but go to the mix window...try holding control+apple and click on the input of the channel. That should activate your input. If not, have you tried trashing prefs (DAE folder, digisetup, Protools prefs, and any com.digidesign files in the pref folder), emptying trash, and restarting? What about trashing all the digi database folders on all drives? I would also repair disk permissions (on your mac HD) through Apple disk utility.
Hopefully this will help.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2018.7
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Instrument Input greyed out lexaudio macOS 2 10-22-2013 04:17 AM
Input>Plug In Greyed Out typhy macOS 1 08-15-2011 06:17 PM
plug-in as an input is greyed out? thenewnoise Pro Tools TDM Systems (Mac) 2 08-14-2011 09:22 PM
Using Mbox Pre's into an 002 Line Input's zero-dB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2006 10:27 PM
Input Selections Greyed Out GJH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-21-2005 03:58 PM
