How to feed both analog and digital outputs?
How could I route the stereo output to the analog outputs 3 and 4 AND to the digital output of 96 i/o? I know it's somewhere in the manual, but I can't find it...
Re: How to feed both analog and digital outputs?
Use the Control modifier key to assign to multiple outs... it works in the Hardware Setup dialog as well.
Rail
Hey,
Go to your input/output menu under setups. Then select both the analog and digital outputs together using alt + shift + control + click and the signal going out your analogs will also go out your digital... Cheers
IMDB |
Thanks Rail and garret. You rock!
hey guys, I've got the same trouble which drives me crazy.... I tried to do what you said about going to i/o menu and selecting both analog and digital outputs. Where do I need to click while pressing ctrl + shift + option?
thnks |
thnks |
Hi
Above the ouput path that you want to send to both analog and digital you will see the output setting for your interface. Click here and you will see all availible output paths. Now to send to both use the control modifier key here and select your digital out or your analog; whichever is the one not selected. A plus will appear beside the output to let you know its going to more than one output. Cheers
IMDB |
Thanks for the quick reply, Garret... You do that at the mixer window, right? That's what I'm doing right now... It's more like using a send to route the signal to a second buss... What I wanna do is to change default I/O path to both analog and digital so that in every session I work the signal goes out of both without changing anything....
We did it by configuring in the HARDWARE SETUP. If you always want output 1/2 to go to 1/2 analog and 1/2 digital, you can select the multiple outputs here and they will always be routed that way.
You could also have 1/2 analog and any other multiple, not just 1/2 digital. Hope this helps.
Eric Seaberg San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Analog Outputs | Edson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-03-2007 11:48 AM |
Is there a way to get 16 analog outputs? | Avi Bortnick | Pro Tools M-Powered (Mac) | 1 | 01-19-2007 11:25 AM |
Digital feed back on play back after Bounce | drew88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-12-2005 01:18 PM |
crashes with digital & analog outputs | Byfar Prod | Pro Tools TDM Systems (Mac) | 1 | 03-12-2003 08:58 AM |
Can the aux input feed the main outputs? | uno1234 | ProControl, Control|24, Command|8 | 3 | 04-11-2001 02:22 PM |
