Old 07-17-2005, 03:14 AM
beheman beheman is offline
Default Newbie!!!
Hi. Rank newbie here!! So go easy. I am running ProTools LE with an MBox on a Celeron 2.8G and I'm running 1GB RAM but the HDD is only 5400rpm so I am looking at buying a 7200 external drive for audio..... my qusetion is : Do I maintain the ProTools LE files on the boot drive and just use the new 7200 for the audio files???? Or do I move all the proTools stuff to the new drive and partition it???
Any kind advice appreciated...
Old 07-17-2005, 03:58 AM
Gkyaun Gkyaun is offline
Default Re: Newbie!!!
What i do is i put all the protools program files on my internal, and then when i go to "Create New Session" in PT i make the session files in the external HD.
sincerly mine, always and forever,
Gkyaun
go left next time
Old 07-17-2005, 05:55 AM
spkguitar's Avatar
Yes.
Old 07-17-2005, 02:14 PM
JustMe JustMe is offline
welcome to the duc!
yes...'ProTools LE files' on the system drive, save sessions on the new 7200 internal/external.
[img]/images/graemlins/cool.gif[/img] Ob-La-Di Do Do Do, Ob-la-da Da Da Da [img]/images/graemlins/cool.gif[/img]
they call me The Thread Killer
Old 07-18-2005, 03:09 AM
Thanks for your help guys.....
If I have one of the non-supported chipsets what kind of problems may I face?
(I have to admit I didn't even look at the chipset when I bought the PC!!??!)
Thanks again??
Old 07-18-2005, 03:38 AM
Joe Evans Joe Evans is offline
Welcome to the DUC. As stated before, leave the program on the first drive and use the 7200rpm drive for the audio files. PT will run with everything on one drive but you get much better performance with a seperate audio drive. As far as the unsupported chip set, you might get anything from simple errors or poor performance to PT not running at all. Which MB and CPU do you have?
In some cases unsupported chip sets are unsupported simply because Digi has not tested their stuff on them. In other cases they have tried then and they absolutely will not work. Hope your case is the former not the latter. Many of the best performing MB's and CPU's are ones that were initially called unsupported and some brave souls tried them out for us. For example, the AMD 64 CPU's were on the list of unsupported hardware at first. Again, welcome to the club.
--joe
Old 07-18-2005, 03:42 AM
Oops.
I just re-read your post and saw that you have a Celeron CPU. I think you might be out of luck with that one in this case. I don't think anyone has had success with that CPU and Pro Tools. Good luck though.
From the compatibility docs.....
Known Incompatibilities
Computers with motherboards containing SiS (Silicon Integrated Systems) chipsets
Intel Celeron , Penitium III and older processor based computers are not supported
--joe
Old 07-18-2005, 04:41 AM
Bastiaan Bastiaan is offline
On the other hand, i run ptle 6.9 succesfully on a Pentium III. Low trackcount, but still...it works, and quite good i might add (16 tracks davec on piii 850 Mhz). I am using the 5400 rpm harddisc for that, and am able to get 32 track playback....
Back in the days the AMD Athlon XP was also on the unsupported list, and have a look now.....
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 07-18-2005, 04:59 AM
That's pretty impressive Bastiaan. I wouldn't have thought a PIII with a 5400rpm drive would be up to the task of 32 tracks on playback. That says something for Pro Tools' efficiency I think. Does the PT GUI get squirrely at all with that many tracks?
--joe
Old 07-18-2005, 05:02 AM
JMS40 JMS40 is offline
I used to get 24 tracks of playback (we were 24 track limited) with a P3 800 as well... just kept the plugs to an absolute minium.
Of course there were no soft synths in our world then.
The Celeron itself is not as big a problem as the chipset.
Celeron's paired with supported Intel chipset's have been reported to function with Pro Tools.
In the past, the major issue with Celeron's, aside from being less efficient than Pentium class CPU's, has been the fact that it's often matched with off brand (cheap)chipset's, such as ALi Magik....
Can you tell us what the chipset is in your system beheman?
Can anyone help a newbie to PT9 please? dal007 Pro Tools 9 8 03-19-2011 11:58 AM
I would say i'm a newbie but... robro86 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-07-2006 06:27 PM
Help a newbie? Rip17 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-25-2005 09:27 PM
Newbie M-box digiplex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-05-2004 10:09 AM
Midie Newbie with newbie questions. cydonia MIDI 5 08-11-2002 02:24 AM
