Old 07-12-2005, 08:12 AM
Gibsonexpl Gibsonexpl is offline
Default Garage Band / Reason / Pro Tools
Hi. Can someone tell me what I have to do in order to use Reason (adapted) & Garage Band within Pro Tools????? Reason does show up under the Plug-ins, but I do not where to go from their.
Is it possible to use Garage Band in Pro Tools or can I / do I create in Garage Band then import into Pro Tools? Thank You.....
Computer Specs:
Apple G5
Dual 2.7gHz
2 gigs o' ram
Tiger
Old 07-12-2005, 08:26 AM
Gkyaun Gkyaun is offline
Default Re: Garage Band / Reason / Pro Tools
To use Reason in Pro Tools put the Reason plug-in on a stereo aux track, and then you should get a small plug-in window that has "Rewire" on it and on this window select "Mix L-R". Start Reason. Actually, when you insert the plug-in on my computer, it starts Reason automatically. After it loads, you should be ready to go with routing MIDI in and out of PT.
As far as i know, Garage Band supports Rewire, but only as a host, and not a slave.
sincerly mine, always and forever,
Gkyaun
go left next time
Pro Tools and Garage Band tomyco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2011 08:30 AM
Pro Tools and Garage Band caine27 General Discussion 1 10-10-2011 05:09 PM
Garage Band with Pro Tools LE 7? sjmagri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-18-2006 11:55 PM
PRO TOOLS 6.4+GARAGE BAND+REWIRE O.T.T.O 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-10-2005 08:42 AM
Using Garage Band with Pro Tools? ragbor MIDI 0 06-24-2004 12:47 PM
