Old 03-15-2005, 10:20 AM
Zetajazz44 Zetajazz44 is offline
Default Loud Noise from Q-10...
About 2 weeks ago I started having this problem... I've not made any changes to my PC or installed anything new... But when I try to insert Waves Q-10 EQ onto one of my tracks, the meters peg out and a very loud noise is made... Anyone ever have this problem and what is the cure...?
Thanks in Advance,
Zetajazz44
Old 03-15-2005, 01:15 PM
hotstuff hotstuff is offline
Default Re: Loud Noise from Q-10...
Hi there!
I had this problem and if I remember correctly I had a session with reason on an aux track and this made protools behave strangly and I think it was one of the instrument in reason that was causing the problem, when I loaded the plugin my monitors nearly blew up and i almost went deff Do you have reason in that session? What version of waves?
Old 03-15-2005, 01:30 PM
Naw, I don't have Reason... I am using Waves Diamond Bundle 5.0... The sound you are describing sounds like what I'm getting... When it does it, you can feel the 'air punch' from the monitors... Not to mention it scares hell out of you and anyone in the control room...
Thanks in Advance,
Zetajazz44
Old 03-15-2005, 02:11 PM
markblasco markblasco is offline
I sometimes get static so loud that all of the meters peak and it hurts my ears, but my problem is when I have several instances of the Finalis limiter along with several instances of the Waves Renn. plugins. It sure scares the buh-jesus out of me everytime it happens (which is completely random and about once every month or 2)
Old 03-15-2005, 02:32 PM
Gkyaun Gkyaun is offline
The Q-10 does this if you try and boost or cut the gain in it. basically, it's crap. i use it on a HD|2 Accel system and if i boost or cut more than 6 or 7 db then it distorts....i dont know.
sincerly mine, always and forever,
Gkyaun
go left next time
Old 03-16-2005, 12:20 PM
ScorchedEarth ScorchedEarth is offline
I know exactly what you are talking about. I have had this happen to me using any Q Equalizer. The wierd thing about it is that it is not consistent. In some sessions it works or works for awhile then it pegs out. Even when I open a new session and insert the plug, I have had it peg out instantly without even messing with the settings on it.
Old 03-16-2005, 01:30 PM
Yes... And while it's pegged out, you can load a pre-set from the menu, and it goes away... BUT, sometimes, if you've got a plug in-line just after the EQ, it pegs it out as well.. and you have load a pre-set there, or delete it... I have had to close the session and re-open it after this happens, as sometimes all audio goes away after this... The session 'plays' but no sound...
Sure wished I could find a cure for this... I don't know how many more times my heart will stand that loud noise!
Thanks in Advance,
Zetajazz44
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini Bigpit Windows 1 09-09-2013 09:26 AM
Kontakt Player loud loud noise at play stop Sven62 MIDI 3 05-05-2011 01:43 PM
loud noise Tombolino General Discussion 0 09-14-2006 03:29 PM
Loud 192 fan noise Chris Coleman Pro Tools TDM Systems (Mac) 2 01-04-2006 08:54 PM
Loud Noise...? Zetajazz44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-25-2004 08:17 AM
