Old 07-12-2018, 06:27 PM
Jcalla Jcalla is offline
Default Pro Tools 2018.X on OS X Mavericks 10.9.5?
So is anyone using a version of PT 2018 on Mavericks 10.9.5 that can attest to the performance of this setup?
P.S.: To those about to say that Mavericks is no longer secure, you're right, but there's really minimal risk when you're not connecting drives that aren't yours and don't really surf the web on that specific machine, so I'll take my chances.
MacBook Pro (16-inch, 2019), 2.3 GHz 8-Core i9, 16 GB RAM, macOS 10.15.7.
M1 Mac mini, 16 GB RAM, macOS 11.6.4.
Mac Pro (Late 2013), 3.5 GHz 6-Core Intel Xeon E5, 16 GB RAM, macOS 12.2.1.
Pro Tools 2021.10
Cubase Pro 11.0.41
Logic Pro X 10.6.3
Apollo Twin DUO MKII
UAD-2 Satellite QUAD Thunderbolt
Old 07-12-2018, 07:22 PM
BScout BScout is offline
Default Re: Pro Tools 2018.X on OS X Mavericks 10.9.5?
ProTools 2018.x versions use METAL to handle its GUI.
Mavericks does not support (preceded the introduction of) METAL. macOS El Capitan is the first that introduced METAL on the Mac.
Good luck.
Old 07-12-2018, 08:50 PM
YYR123's Avatar
YYR123 YYR123 is offline
[QUOTE=BScout;2493978.... is the first that introduced METAL on the Mac.[/QUOTE]
Metal on the Mac
Daniel
Old 07-12-2018, 09:54 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Right on.
METAL on the Mac
Old 07-13-2018, 04:12 AM
Good luck.
So this means then that anyone with a cheesegrater Mac Pro is out of luck for running PT2018 unless they change out their video card? Standard cards that come in those machines don't support metal afaik.
Old 07-13-2018, 05:01 AM
KV626's Avatar
KV626 KV626 is offline
Good luck.
Pro Tools does NOT use Metal. There's a big misconception that since the introduction of Metal in El Capitan, every app somehow "has to" to be using Metal to work under El Capitan/Sierra/HS - not at all. Metal is actually used mostly in games, but for a vast majority of apps out there, including Pro Tools, Metal is almost irrelevant. That's about to change with Mojave though, but that's because Apple chooses so. I bet PT 2018.x will still work under 10.14, and will still not be using Metal in any way shape or form. As frustrating as it may be for Apple, Open GL still has to be part of the OS. And as Jack said above, the stock GPU in the 2010/2012 Mac Pros doesn't support Metal, yet PT runs perfectly fine on these machines, not to mention El Cap, Sierra and HS by the way.
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 07-13-2018, 05:03 AM
skizzo skizzo is offline
I don't think that is what his point was. He was referring to the operating system version, not the GPU. As in if you are on too old of an OS then PT 2018.X will not have proper GPU support, even if you have a metal capable GPU.
I can say that your assumption is wrong. You can run PT 2018.X with a GT120 which is the stock 2009 4,1 cMP GPU. I use that along with a more modern GPU being the RX580
So I would also go back to the earlier comment and say its pretty obvious that PT doesn't require metal supported GPUs when I can run it perfectly fine with a GT120 which def isn't metal capable
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM
970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions)
HD5770 GPU
OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+
Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76
Old 07-13-2018, 05:25 AM
I was going by what BScout wrote. He wrote that PT2018 used metal which was available in El Crapitan & above and going from that that would leave people out who had the stock video card in their cheesegrater. By extension the gpu thus enters the equation.
Old 07-13-2018, 12:49 PM
Thanks everyone for your comments, I have a feeling Avid's going to release a new version of PT this month (because they already released MC First 2018.7) so I'm going to wait until that happens and then try my luck and post back.
So after trying it out, PT 2018.4 launches on Mavericks but playing around in it causes it to crash, so it's unusable. I downgraded to 12.8.1 and it works great even though it's not officially supported (12.7.1 last supported Mavericks I believe).
Pro Tools 2021.10
Cubase Pro 11.0.41
Logic Pro X 10.6.3
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Pro Tools 2018 with Pro Tools Control on iPad - connection problem JacobSoundStudio Pro Tools 2018 4 06-25-2018 01:24 PM
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 04:41 PM
Pro Tools HD and Mavericks ? Chromefree Pro Tools 10 26 03-02-2018 05:42 AM
Pro Tools LE 8 on Mavericks agusmaki 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-01-2014 09:37 AM
