Old 07-04-2018, 03:16 PM
BScout BScout is offline
Default Re: 2018.4 cpu spiking all over the place
Originally Posted by tomstephens89 View Post
I have read elsewhere that Nvidia drivers and pro tools disagree.
4 systems with Nvidia and they all work flawlessly. All HDX. So nope.
But all Macs.
However, 96k with 64 buffer isn't really supported. 128 is the minimum. 3.5 ms vs 5.3 ms.
Oh well, to each their own.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 07-05-2018, 01:08 PM
I do wonder if this is somehow related to the fact I have an Nvidia quadro in my system and pro tools disagrees with it.
Just the opposite. nVidia is preferred
Old 07-06-2018, 07:15 AM
risey's Avatar
risey risey is offline
Hi there, I have been using PT for years and always had an NVIDIA card installed, never a problem. Now.... the CPU spike could be caused by your Audio card you are using especially USB based audio cards. I noticed while using my 18i20 2nd gen (USB) I would get spikes, but when using my Mbox Pro 3 which is a firewire audio card I had zero spikes.
So try updating your USB drivers first for your motherboard, update to the latest bios also. CPU microcodes are being updated regularly since the intel revelation months ago which brings me to my next point. My previous CPU was an i7 5960x when windows rolled out a microcode update followed by my motherboard manufacture rolling out a bios update I lost 20% performance and had loads of spikes when using pro tools. In the end I built a new system around an i7 8700k and although that CPU is also affected by the microcode mess by intel the hit is far less noticeable.
One thing you could do is check which core is receiving the spikes and disable it for Pro Tools. Pro Tools multicore support to be honest is not that great, Avid shifts the blame onto 3rd party plugins but that is another topic, but what used to happen on the first version of Pro Tools 12 is that core zero (first core) would spike causing 100% usage report while other cores were almost dormant, for some users this could cause PT to crash.
An old gamers trick can temp fix this. Check which core is spiking the most, if it is the first core you can disable this and leave that core for your system, to do this run pro tools, then go to TASK MANAGER, look for Pro Tools, right click on it and choose GO TO DETAILS, right click the avid or pt exe it has chosen and choose SET AFFINITY, untick core zero. This will now free up core zero to system processes and PT will not use it, when u restart Pro Tools it will reset itself again so you will need to go through the same process.
If another core is spiking just do the same on that core but leave core zero active and see if the work load is then distributed more evenly amongst the cores.
http://www.PhatMonkey.me
Windows 10 64bit | Asus Rog Hero Xi | Intel i9-9900K | Corsair LPX Vengeance 64g DDR4 RAM | Avid Mbox Pro 3 | Focusrite 18i20 2nd Gen | MSI RTX 2080TI Gaming X Trio | Acer Z35 Predator Monitor
Old 07-06-2018, 09:13 AM
jjnssn jjnssn is online now
I have been using quadro cards on my last 3 pc builds. P1000 recently. Works very well. Nvidia driver has highest DPC latency spikes however well below any level of concern.
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Old 07-06-2018, 12:32 PM
Doesn't have to do with USB. Has to do with Focusrite having bad USB drivers. They've had a lot of problems with their drivers for the USB series and Pro Tools.
Old 07-11-2018, 06:22 AM
chrismeraz chrismeraz is offline
OP, I can run small sessions with no plugins at 96k and 64 sample buffer. However, there is a lot of CPU spiking going on and it is not reliable. It's just part and parcel of how PT processes audio.
If I'm recording, I'll keep my sample buffer between 128 and 512.
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Old 07-12-2018, 08:31 AM
feliponk's Avatar
feliponk feliponk is offline
Try with a different driver, or if you can a GT series board, a $ 50 works just fine. ProTools doesn't rely heavily like MC does on the Quadro series
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Custom Mac Pro OSX Sierra | Windows 10 Pro 64 | ProTools HD 2018 | Pyramix V 10 | Merging HAPI ADA8 | MBox 3 | UAD Quad PCIe | Avid Artist Mix | Kali LP-6 | Presonus Temblor 10 | Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 04:41 PM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
CPU spiking 11.1.1 wesm Pro Tools 11 8 01-07-2014 05:58 PM
Cpu spiking cmotard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2010 08:17 AM
