  #291
Old 08-15-2010, 06:58 AM
KKalampo KKalampo is offline
Default Best Systems and Components for Win HD/TDM
I want to build a machine for pro tools hd2 pci-e and 192 Digital I/O.I'll be using win7 64bit.Do you know any specific hardware (motherboard, graphics card, cpu, memory sticks) that work well with pro tools?
Thank you
  #292
Old 09-13-2010, 08:35 AM
valeriomaina valeriomaina is offline
Default Re: Best Systems and Components for Win HD/TDM
Hello to everybody
in august i built this pc:
CPU I7-920 2,66G 8MB
Asus Motherboard P6t6 Ws Revolution
DDR3 4GB 1333 KINGSTON KIT
S.G. ATI ASUS H4350 512MB
HD WD 500 GB SATA 32MB
Thermaltake 750W TOUGHPOWER
PROTOOLS HD 2 pci-e
and the o.s. is win 7 64.
i use ad/da 192 by digidesign, linked via aes/ebu to an apogee rosetta that is the master clock.
in theese 2 months all worked fine (before i used protools le on a dell latitude workstation)
i just followed the advice of Seagate Studio and i installed the core card in the slot furthest from the CPU
any question is welcome
Valerio Maina
  #293
Old 09-21-2010, 03:23 PM
docric docric is offline
System below (see sig.) works great so far...
Will post in a couple weeks to confirm stability.
IHTH
-C' ya'
Rick
MacPro 6,1; 12 core; 64 Gb RAM; 1 TB Samsung 970 Pro w/ adapter & heatsink; OSX 10.14.5
PT 2019.6.0 Ult.
Burl MS / PT Dock/ Eucon 19.5.1/iPad Air2/ iOS 12.3.1/ProTools|Control
  #294
Old 09-27-2010, 04:25 AM
Raoul23 Raoul23 is offline
IHTH
Hi docric hows the system going now all stable with 3 cards running
Thanks Raoul
  #295
Old 09-27-2010, 09:38 AM
Originally Posted by Raoul23 View Post
...hows the system going now all stable with 3 cards running
Running great Raoul... Solid, no crashes.
Haven't put it through a really dense VI test yet, however... but no probs at all with 4-5 VIs/40 audio tracks playback while tracking 2-3 tracks per pass...
HTH !
-C' ya'
Rick
PT 2019.6.0 Ult.
  #296
Old 09-28-2010, 12:57 AM
HTH !
Thats great to hear Docric im getting me one of those pcs made. As i live in the uk i cant get one of the cases you have would any case be ok or would it have to be quite large to fit the cards in
Thanks Raoul
  #297
Old 09-28-2010, 04:07 PM
The PCI cards are fairly long, and in the standard mid tower case that I originally purchased, they just wouldn't fit... Is there a shop around you that sells parts? If so, I'd measure your HD cards, then go and take some case measurements.
If not, I'd def look for the DEEPEST tower you can find to build it. Maybe call the sales folks at whatever online shop your looking at and ask them specifically.
Maybe someone who built their's in a tower can chime in here?
Good luck with the build, Raoul... it was a major PITA at times for me, but is proving itself more worthwhile each day I work on it.
-C' ya'
Rick
PT 2019.6.0 Ult.
  #298
Old 10-05-2010, 03:48 PM
Well, like the PC Noob that I am, fried the prior mobo & processor putting in a silent cooler... Couldn't find another one anywhere...
Good news is that I found a different mobo that works great for HD3 (no dremel necessary!) ...and, most importantly, IS CURRENTLY AVAILABLE
...one more for the pile...
GIGABYTE GA-H55-USB3
(yep, KevS, it works...)
-C' ya'
Rick
PT 2019.6.0 Ult.
  #299
Old 11-22-2010, 01:01 AM
Fullsound Recording Fullsound Recording is offline
Default 6031 errors
Always consider IRQ guys, The UAD card I have some times will for no reason set itself to IRQ 17 where my main core card is and things go south fast. Then I pull the UAD card, Re boot then shut down, The re install UAD card then confirm its iIRQ sits at 18 or any where else- Then its all good again
Now if your MB Bios will allow then you can hard set the IRQ to SLOT paths. But anything that sits in the CORE card IRQ blows 6031's in a heart beat here and at a few other folks places i have been.
While there are many other sources for this error I can assure you a stacked IRQ will yield this error fast. Or random making it seem so untraceable.
http://www.helpwithpcs.com/upgrading...q-settings.htm
www.fullsoundrecording.com
Seattle Wa
I voted at www.deardigi.com
  #300
Old 11-23-2010, 09:11 AM
tonzone tonzone is offline
Hi all,
there is a quite new P55 board from MSI with 3 PCI-slots.
http://www.msi.com/index.php?func=pr...0&prod_no=2078
No dremel tool required
I have done a few tests with W7 Ultimate, HD2 PCI, this board and the Intel 875K processor - all is working and the results are pretty amazing!
Only downside is the lack of firewire, but there´s no problem with a FW PCIe card.
I have also tested with the Snow creature, and the performance is at least 2-3 times faster than my older Mac Pro Quad 2,66
Cheers
Zig
Are these pc components ok? chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 08-13-2010 11:20 AM
need help with HD components FMR_Crisis Pro Tools TDM Systems (Mac) 9 04-17-2010 05:07 PM
What components lie in the most POWERFUL native PTLE Systems? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-28-2008 07:18 AM
Will these PC components do the job hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-06-2007 08:22 PM
components rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-19-2001 09:32 AM
