Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-14-2000, 10:37 PM
JKMarcelin JKMarcelin is offline
Default Damaged Audio File
This weekend, I tried restoring some old 4mm DAT backup tapes (about 4-5 years old) to backup to CD. During the restore, Retrospect 4.2 crashed with 49k left for the file to be complete. I tried it several times and it crashes at the same place every time. The audio file is part of a stereo set but Logic Audio, Protools 5, and every other audio playing application won't recognize the file. Does any one know of an application that may be able to salvage part of the audio file. The file format is SD2/16 bit from Session 8. This has peaked my interest in knowing how an audio file is put together. Any help is appreciated. Thanks.
Old 02-15-2000, 03:47 PM
coaster coaster is offline
Default Re: Damaged Audio File
i am not sure what type of file is the one in question, but if it is a headerless audio file you might be able to open it as a 'raw' audio file in soundhack. this is the program i use to change headers quite often, but i suspect that the crash you speak of may be causing a different kind of problem to the file. do you have a different back up copy?
www.mp3.com/xtac
for the faint of goth
Old 02-20-2000, 03:51 PM
Thanks for the tip!!! Sound Hack worked. It opened up the file as a "Headerless" file and I resaved it as a an SDII file. Logic Audio had a problem with it because it was a stereo file and now one was a little shorter than the other but it did recognise the file. It was an all audio session and I was moving it into PT5 anyway so it did not matter. Once again, Thanks.
damaged sd2 file recovery needed jimfisheye Pro Tools HDX & HD Native Systems (Mac) 1 04-13-2012 09:02 AM
'save a copy as' damaged a file - file repair advice? Artysan Pro Tools TDM Systems (Mac) 8 03-26-2011 06:14 PM
Upgrade to ProTools LE 8 - Downloaded file damaged gabrielracy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-12-2009 08:10 PM
Damaged Session file? DigiTone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-02-2006 01:00 PM
-39 End-of-file damaged aiffs diegosaenz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-09-2005 10:28 AM
