"Marker Zero" in PT2023.12: Unable to recall from keypad
Hi all -
LOVING the new marker features in 2023.12. Fantastic! One exception: Formerly, you could set and recall marker 32000 by using the "zero" key. 1) Set marker 32000: .0[enter][enter] 2) Recall marker 32000: .0. Now 1 works but not 2. Personally I'd consider it a bug, then again maybe it was a fluke that zero worked at all. Hoping but doubting there's some magic workaround for recalling marker zero from the keypad Hoping there'll be a fix. Here I use "marker zero" as my "working marker" ... set and recall probably 500x a day. Not kidding. Personally I'll move immediately to marker 4 (closest to zero that's not 1 which I use for "in point") which is what I used before marker 32000 (marker zero) started working, which changed my life for the better. -jeremiah |
Re: "Marker Zero" in PT2023.12: Unable to recall from keypad
Thanks
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
Yes please to fixing this! I only just discovered Marker Zero a few months ago, but it’s been a game changer since it is never set as a default marker and would take ages to get to sequentially (32000). I used to use Marker 55 as my “return” marker, but if I forget and then have a bunch of markers, then I have to go through the cycle of switching it and yada yada yada. Hope it can be an easy fix!
I also use it 500 times a day
~Will |
I've just got confirmation from Engineering that it is a bug and they are aware of it. They'll be working on this. Thank you!
I hope you guys don't mind if I create cases for you so I can associate it with the bug ticket opened.
Thank you
Absolutely create a case for me! PM me if you need details.
-jeremiah |
Teamwork peeps. Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
Thanks! PM if you need info.
~Will |
Yeh.
"1" and "2" on keypad for moving the cursor | SWSPHX | Pro Tools TDM Systems (Mac) | 6 | 07-09-2022 03:14 PM |
(Feature Request?) When bouncing, option to use file name as new "Recall Session" | jaminjamesp | Pro Tools 2019 | 7 | 03-23-2020 09:33 AM |
"Error 0028" + "Unable to perform elastic audio" | themelissacheri | Pro Tools | Intro Discussion | 0 | 08-29-2016 02:06 PM |
PT Shortcuts "Editing, Nudging an Trimming" with LMP Numeric Keypad | TableTopJoe | Pro Tools 10 | 1 | 03-17-2015 08:22 AM |
"unable to parse audio file" and "OSStatus Error -208" ! | reichman | Post - Surround - Video | 2 | 03-22-2010 04:46 AM |
