Re: Connecting preamp to compressors to interface
Maybe(I don't own one so I can't say for sure). Consult the manual AND the Focusrite software for routing and setup. As for phantom, if you use a TRS connection, the phantom voltage NORMALLY is not applied to those connections(but again, read the manual), but turning phantom power off does not make it a line level input. Why it matters is that all the external things you want to connect have line level outputs and those would overdrive a mic level input. You also could open a support ticket with Focusrite and ask them about how best to connect an external mic preamp to the input of your interface. Or maybe hit youtube and search for "using an external mic preamp with focusrite 18i20"(without the quotes)
https://support.focusrite.com/hc/en-...e-Mic-Preamps-
That's what I was referring to - it shouldn't matter either way. Theoretically, the less wiring or connections the less noise, but if one way works better for you than the other just go with it. Personally, I'd probably just go from one output to the next input and not mess with the inserts.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Connecting an external guitar-preamp. | JCcares | Eleven Rack | 3 | 05-10-2016 03:08 AM |
Connecting external preamp | Maddern | macOS | 4 | 12-23-2012 08:08 AM |
Connecting and Setting up and external preamp | lew742man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-17-2008 09:10 AM |
PreAmp/Compressors | daveo32 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-12-2004 06:37 PM |
Connecting Preamp to Digi001 | Allen Hallada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 02-21-2002 08:30 AM |
