Old 10-06-2017, 10:02 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Commit or Freeze with Heat (HDX) causes Pro Tools HD to hang
Heat remains an issue when offline Bouncing mixes, stems and Committing.
App man stated it was fixed although no change at this end. (My Sig)
Anyone else?
Old 10-08-2017, 05:46 PM
loopzilla2 loopzilla2 is offline
Default Re: Heat with HDX
Def not fixed on my system. Took a day, pulled all plugs, reinstalled a few at a time - no difference. What I discovered was:
if there are no audio tracks of any kind, instrument tracks bounce and commit wonderfully. Adding an audio track with HEAT active screws everything up. No more bouncing and committing.
Hope this helps.
Old 10-08-2017, 08:24 PM
khoop2112 khoop2112 is offline
Same here - if I freeze or commit any track I get spinning wheel of death and have to force quit PT. If I disable HEAT then try the same thing it's fine 100% of the time.
Old 10-08-2017, 09:07 PM
YYR123's Avatar
YYR123 YYR123 is offline
Sorry I’d couldn’t see your sig
What version of PT?
Daniel
Old 10-10-2017, 11:57 AM
Dan IceWood Dan IceWood is offline
What version PT, have you trashed prefs ?
PT HDX or PTHD NATIVE
Old 10-10-2017, 12:50 PM
YYR123's Avatar
Well the main issue dan is that the Readme said there were issues.
So avid knows about them....
Daniel
Old 10-10-2017, 02:52 PM
JFreak's Avatar
JFreak JFreak is offline
I have never had issues with HEAT but then again I don't have HDX, only TDM and HDN
Janne
Old 10-11-2017, 09:09 AM
jeffro's Avatar
jeffro jeffro is offline
Originally Posted by DetroitT View Post
Heat remains an issue when offline Bouncing mixes, stems and Committing...
Can you please be more specific? Is it the same issue mentioned by khoop2112 or is it something different? Thanks.
linkedin
Old 10-12-2017, 06:03 AM
DetroitT's Avatar
Yes the same. With Heat engaged OFF-Line Commit just hangs and requires a "Force Quit"
Go real time with Heat commit works.
Turn Heat off the Off-line commit works.
My signature is up to date.
Old 10-12-2017, 09:48 PM
Same here - most recent version of PT and I cannot commit or freeze any tracks when HEAT is enabled. When I disable it everything works as it should....
HEAT not included with Track Commit zam226 Pro Tools 12 6 05-19-2017 12:02 PM
Vacuum VI won't Freeze or Commit? Bushpig Pro Tools 12 8 12-24-2016 11:52 PM
Track commit/freeze Thenewexhibit Pro Tools 12 2 12-23-2015 02:50 PM
Commit Tracks and HEAT Siegfried Meier Pro Tools 12 10 11-13-2015 05:37 PM
