#91
Re: MiniGrand Permanent Workaround
Thank you for this!
MacBook Pro: 16GB M1 Pro 8c Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580 Pro Tools Studio, RME RayDAT PCIe http://www.liamgaughan.com |
#92
Thank you! Worked here.
So, would this be an Apple, Air or Avid fix-to-be?
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
#93
Seeing as how there are other DAWs complaining the issue over at the AIRMUSICTECH forum, I'd guess it is AIR and Apple.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob Squaw Creek Road Studio Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1) | M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) | 3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 | Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X | |
#94
OP already mentioned this, but it bears repeating - this fix only works if you leave the .big file where the installer wants it to be. If (like me) you keep your VI libraries in a different place, it won't work.
Also, the update to 10.12.2 didn't change anything here.
PC workstation: Windows 10 Pro i7 12700K RTX 2080ti 64GB DDR5 5200mhz RAM 2 Samsung 980 Pro 1TB SSDs Samsung 850 Pro 1TB SSD LG 34" Ultra-Widescreen monitor Pro Tools 12.4 A loaf of bread A stick of butter A lot of rye whiskey |
#95
Re: Mini Grand and Structure still a NO GO
Well, after hours of testing Mini Grand and Structure Free I have an update.
I cannot get Mini Grand to falter using the plist file from Vickie, and thank you again for it, however, applying the temporary fix also to com.airmusictech.Structure.plist allows Structure Free to work as long as you only use the stock patches provided. On my system, when you go to the Structure Free browser and start searching for other patches to use, that's when it will fall apart again. It's all OK until you save and exit your session and that's when the com.airmusictech.Structure.plist file gets written to with updates of your browsing locations and other pertinent information and the two keys are overwritten again and the next time you use the VI Structure Free, it won't work until you modify the two suspect keys again. I was so excited that it began to work at all that I hadn't tested it fully for browsing and adding your own patches and didn't realize that it would crater again. Sorry to have mislead anyone on this. But Mini Grand still works great! |
#96
Re: Air Mini Grand: no "long" sound, just short notes...
Is there a solution? Since 12.7 installation Structure doesn't work anymore...
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
#97
AIR Music Mini Grand Plug-In Not Working --Bug FIX---For Pro Tools: https://youtu.be/vohwf_OAVJM Still gotta repeat this procedure every time! AIR Beta Forum’s currently “down” .... I’ve emailed Simon Bangs from inMusic about this issue .... I’ll bump it in the New Year ....
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor |
#98
Thank you
#99
2GB of Loopmasters samples with a broken sampler.
#100
I have the same problem. I'm using a Yamaha Portable Grand DGX 200 keyboard as my midi controller. I record with the sustain pedal on, but when I go to play it back, I can only get Mini Grand to play the sustain by stepping on the sustain pedal. And only when the instrument track is record enabled. And I can't get the sustain to work when I bounce the track, either to an audio track, or to disk. It's just stacatto notes.
I haven't been able to figure out where this information is stored in the midi. But it must be there because the sustain does work when I play back per the above. But even when the sustain is working, some notes still cut off early. Any help is much appreciated, thank you. I'm running Pro Tools 12 on a Dell Latitude E7450. |
Quatize make short notes | Shasho | macOS | 1 | 07-11-2013 09:13 AM |
Where Did Extra Long and Short Delay II Go? | Trailerman | Pro Tools 10 | 6 | 01-18-2012 01:57 AM |
Mini Grand in PT9 no sound and crashes. | eddicuz | Virtual Instruments | 0 | 04-04-2011 12:46 PM |
1 long session or several short? | Andrew814 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-19-2008 02:49 AM |
ADC, Short delay or Long dalay?? | bobo mark | Pro Tools TDM Systems (Mac) | 1 | 02-24-2006 06:01 PM |
