Mic works w/o phantom power on Avid Solo
I am using this sE Electronics microphone with a new Avid Fast Track Solo. I have noticed that Protools will record even if the phantom power switch is off. I thought the mic required phantom power and I need to have the Solo phantom power switch turned on. Can someone help me understand what is going on? Why does the mic work without the phantom power turned on?
Thanks, Mike |
Re: Mic works w/o phantom power on Avid Solo
Maybe your phantom power switch is broken or stuck? Better to be stuck ON, than stuck off
The phantom power indicator light (red on the front) turns on and off when the switch is changed. So I assume the mic should not work at all with phantom power off, right?
Many mics will still operate at a reduced dynamic range at lower levels of DC. Either your interface input is still carrying a residual DC charge or the phantom circuit is leaking enough DC to allow the mic to operate.
Parroted by me & Tapasquawk
At this point I don't know if my Fast Track Solo needs a repair or not. The microphone supposedly requires 48 +/- 4 Volts. I have a multimeter. How do I measure the voltage? Is the outer casing ground?
Thanks, Mike |
pin 1 is ground
so you should see 48V dc (maybe a bit higher with no load) between pin 1 and pin 2 or 3 you should see 0V between pins 2 and 3
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Here are the results:
Measured directly on Fast Track Solo XLR plug (no cable involved). Does this mean the Solo is not working correctly? I don't know what to expect if phantom power is turned off. Thanks for your help. Mike |
I would say that something is not working. Has it been like this since day 1? Have you always ensured that Phantom power is turned off before plugging and unplugging your condenser mic? A spike in voltage when unplugging or plugging in the mic could've damaged the circuit.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
I would expect something close to 0V with phantom off.
I'm guessing the switch is not working correctly you basically have full phantom all the time As long as you do not have any vintage ribbon mics I'd leave it
Omni Mic Pres phantom power only works in pairs? | shrootyruss | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-29-2013 08:32 AM |
002R Faults + power harness + no phantom power | DaveSB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-26-2009 01:10 AM |
recording with phantom power *and* without phantom power simultaneously | SweetSoulSound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-22-2008 07:40 PM |
Firewire Solo -- it Works | Maarsmusic | Pro Tools M-Powered (Win) | 4 | 04-29-2005 06:17 PM |
Phantom power and mic with power supply? | hotstuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-20-2005 12:56 PM |
