#21
Re: Eleven rack expansion pack serial "already activated"
You said you DID purchase the ERXP correct? But you never ran it? If you downloaded the program i linked to that IS the firmware updater. The ERXP is a DUAL installer. The UI updater and the firmware updater are linked together. First the UI files get installed, then a firmware update gets placed on the desktop, that is the part that actually installs the new amp, effects, ect... to the physical 11R. NONE of the Amps, effects, mics, cabs, ect... are installed on the computer ONLY UI files that let you view them. I think you have a mis-understanding of what the ERXP is. Can you confim that you have purchased the ERXP? It is $99. Did you ever purchase that from the Avid website?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
#22
#23
#24
The only reason you would need to do it again is if you installed an OLDER firmware OVER the newer firmware. Did you do that? Also the ERXP ID and S/N can ONLY be used from ONE computer, the original computer they were run on. There is NO NEED to update the Firmware from the Mac, there is Zero difference. If you for some reason installed 1.0.3 OVER the updated firmware, you will need to connect the 11R to the computer you used before. And re-update the 11R. your ID and S/N will be in your Avid account.
#25
#26
Thank you, that clears EVERYTHING up. Go back to the PC. Run the ERXP Firmware updater from that Windows Machine, it should run no problem PROVIDED that it is the SAME exact operating system and you did not delete the hidden files that allow the ERXP to run. After you update to Firmware 2.0.1 DO NOT EVER install an older Firmware to the Eleven Rack. There is no need. Thats not how the ERXP works. It does not matter if you are using a Mac or PC. The actual Amps, effects, mics, ect... are installed on the physical 11R unit, not to a computer.
#27
#28
everything is there again...thank you!
#29
Make sure you have the correct drivers (which you should since PT8 includes drivers) and open PT and i'll bet everything will work correctly. IF not, then run the ERXP again, JUST THE FIRST SECTION, no need to do anything to the firmware ever again. If you ever have a question like this again, be sure to post a question first before installing new firmware.
#30
HURRAY!
Now go have some fun with that new computer
Eleven rack (11R) slow booting past "setting up midi" | Edleigh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-25-2011 09:44 PM |
11R Expansion Pack "Custom" Models | Resonant Alien | Eleven Rack | 9 | 05-17-2011 12:06 PM |
Do I need the "Transfer Ownership Audio" form to sell my Eleven Rack? | acmost | General Discussion | 5 | 04-16-2011 12:07 AM |
Steven Slate Trigger "Expansion Pack" | nst7 | Pro Tools 9 | 1 | 04-01-2011 03:50 PM |
New 11R w/ expansion pack, "Output to Amp" question | Gasp100 | Eleven Rack | 7 | 03-25-2011 09:31 PM |
