Using OMF files to edit soundtrack for short film
My name is Steve and I'm mixing a soundtrack for a short film I've just finished shooting. I'm trying to transfer the final FCP QuickTime into Pro Tools in a way that would keep each audio track from FCP in it's own audio track in PT. I know I have to use an OMF file, but every time I try to open the file in PT, it says it can't detect my video engine. I'm new to this style of file transfer so if anyone could give me some advice, I'd appreciate it a lot!
Thanks |
Re: Using OMF files to edit soundtrack for short film
You need to strip out the video from the OMF when you make it in FCP. Duplicate the sequence and remove all video, then OMF that sequence.
separately, you need to export a single quicktime video file that you can open in ProTools as a guide picture.
-- Jerome O'Donohoe - TV and Film audio post in London, UK and thereabouts. www.fade-up.com |
What is the exact wording of the error message?
Video tracks in an omf file are not well supported by Pro Tools. Do not use video tracks, use only audio tracks in your omf. If you've already exported frm FCP with both video and audio tracks, choose only the audio tracks for import. This should give you your audio. For picture, import a flattened movie file as a separate step. In Pro Tools do this from the File Menu: Import: Video. Render your movie out from FCP to a standard QT file, not as an omf. Many people are using ProRes or DVCPro in Pro Tools. Many others say they have good luck with H.264, but only if you've got an 8 core mac. Before any export, it is very smart to place (in FCP) a "2 pop" in both audio and video so that you can be absolutely certain they are sync'd together in Pro Tools. |
This shouldn't even be an issue, as FCP only exports audio to OMF and not picture, unless you're using the Automatic Duck add-on?
Can you give any more info? I've never had the issues you're describing. |
I've just had a thought.
Steve, what command in the menus are you using to import your OMF? and, what Pro Tools are you using? Are you aware you need HD with Digitranslator, or if in LE you need DV Toolkit or Complete Production Toolkit?
http://www.imdb.com/name/nm2585847/ PT Ultimate 2019 MAC WORKPLACE PT Ultimate 2019 Windows 10 Pro HOME STUDIO Less is More |
Pro Mixing Webinar: Creating an Indie Film Soundtrack | Avid | Post - Surround - Video | 41 | 04-12-2023 06:07 AM |
Pro Mixing Webinar: Creating an Indie Film Soundtrack | Avid | General | 0 | 11-30-2012 03:36 PM |
1. Mastering a film soundtrack and 2. roomtone / reverb | peter5992 | Post - Surround - Video | 6 | 10-23-2011 10:27 AM |
48-hour film soundtrack | TieDyedDevil | Eleven Rack | 0 | 02-28-2011 11:57 PM |
Check out my short film mix... | DChung | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-23-2002 09:53 PM |
