Old 12-28-2009, 08:40 AM
jbandhisguitar jbandhisguitar is offline
Angry Horrible Delay and Reverb on "record enabled" in PTLE 8.0
I ran into this problem with pro tools 8.0 while attempting to record with a guitar.
Upon record enable of a track. The guitar gets a horrible delay slap back effect and reverb. When recording something this effect remains as well. When the recording is done and you listen to it, these effects are nowhere to be found.
So :
Record enabled. Horrible slap back delay and reverb
During recording. Horrible slap back delay and reverb
Playback of said recording. No effects to be found.
When record enabled is off and you're just playing normally these effects aren't there.
I made a new track several time and a new session to be sure that this wasn't a track or session problem. It's still there.
I had this problem to a smaller unnoticeable extent with pro tools 7.3 but that was only a tiny bit of reverb. This is so horrible that i can't even hear much of what I'm playing during record. The problem sort of goes away for a few seconds and then it turns back on at random.
I can't find any info on it so I'd appreciate it if anyone knew anything.
Edit:
Out of guess work I'm thinking that normally pro tools is picking up one signal of the guitar and when switched to record enabled for some reason it duplicates the signal causing the slap back delay type effect. Thoughts?
Old 12-28-2009, 09:00 AM
Default Re: Horrible Delay and Reverb on "record enabled" in PTLE 8.0
Originally Posted by Benoni View Post
what is your H/W Buffer set at?
wow, well that fixed it... Looks like it was way easier then i thought.
Huge thanks man!
A little info on that to redeem myself.
Pro tools kept freezing up asking me to increase the H/W buffer for play back so i went from
256 samples to
512 samples to
1024 samples to
2048 samples.
I now see decreasing my H/W buffer got rid of the problem of the slap back effect. Seems i still have much to learn.
Also the exact error message i was getting was this.
"The operating system held off interrupts for too long. If this occurs often, try increasing the "H/W Buffer Size" in the playback engine dialog.
This kept popping up and stopping my recordings so i choose to increase it.
Maybe i need to let my comp rest for awhile?
Thanks again.
Old 12-28-2009, 09:08 AM
Are you on a Mac?
The computers an I-mac but I'm running windows vista 64bit on it.
Old 12-28-2009, 09:24 AM
Why!!
Hahaha. well i always used my mac for music and when i really got into pro tools there were a lot of vst's i needed windows for
So i borrowed my friends copy of vista 64 bit.
I have linux windows and os x on different partition and os x and windows both have pro tools on it. That's pretty much the jist of that :P
Oh yeah plus i didn't have the os i needed for 8.0 i don't think.
Old 12-28-2009, 10:32 AM
Dump Vista and run PT in the Mac environment. I suspect that would make you much happier. Besides, your version of PT is not compatible with any 64bit Windows.
Solution to "Track could not be record-enabled" issue with PT10 and Eleven Rack spankyq Pro Tools 10 8 04-20-2015 08:19 AM
"The track could not be record enabled..." Ewan T Pro Tools 10 4 08-04-2013 07:06 PM
horrible digital static or "feedback" sound JoeQ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-01-2009 08:34 AM
MTC input disabled when "Beat clock to port.." or "MTC to Port..." is enabled OKden Pro Tools TDM Systems (Mac) 2 10-27-2001 03:24 AM
"auditioning" record-enabled tracks markert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-10-2001 10:12 PM
