UnWrap PlugIn by TC
Hi there,
I am pretty new to Pro Tools TDM and the plug-in thing. I just got a demo licence for the UnWrap tool but I can't find it in Pro Tools in the AudioSuite. Can you tell me exactly how to use it? The unwrap file is in the plug-in folder but it doesn't appear in Pro Tools!? Thanks a lot! janeich (I posted this thread also in the surround area, but maybe here someone could help me too) |
UnWrap is not an audiosuite-plugin, - but a realtime-plug-in and should be used on single, - most likely used on a masterchannel or mixbus.
UnWrap is in essence an upconversion-plug, in that it will take your standard stereo-mix and convert it to make a surround-mix. Hope this helps you , - but you really should take the time to read up on it (the manual you know;-)), - as its a great plug. Cheers |
thanks for the quick answer! As I am really new to using Pro Tools, how do I select a real-time plugin on a master channel? When I click on the inserts of a master channel, I can't find the UnWrap plug-in... The manual doesn't really tell how to get started with the plugin. It's about how to hadle the different settings when using the plugin. So that wasn't a help so far. Hope you could help me again Thanks, janeich |
TC unwrap and HDn?? | Brandonx1 | Post - Surround - Video | 7 | 10-11-2010 11:52 PM |
Any opinions on SRS vs. Unwrap | jimlongo | Post - Surround - Video | 31 | 03-09-2009 01:29 PM |
UnWrap PlugIn by TC | janeich | Post - Surround - Video | 6 | 07-29-2008 01:00 PM |
TC unwrap plugin | john1192 | Pro Tools TDM Systems (Mac) | 3 | 07-13-2007 03:12 AM |
Unwrap | doctorsunshine | Post - Surround - Video | 8 | 10-09-2006 04:10 PM |
