Old 01-04-2007, 09:57 AM
CZARUŚ CZARUŚ is offline
Default HOW I CAN DO MONITOR ON MASTER FADER
HELLO
i want to have monitor control to the master fader it's possible or not ?
thx
Old 01-04-2007, 10:03 AM
SteveGam SteveGam is offline
Default Re: HOW I CAN DO MONITOR ON MASTER FADER
Below the solo trim knob is a button labeled "mix to monitors"
When enabled your master fader is sent to the local monitors. NOTE: solo buttons will override the master mix listen.
enjoy,
Steve
Working for the preservation of quality live sound.... One show at a time!
Work
Twin S6L's
PM-10
Profile, D-Show
3 Midas Heritage's and 5 M32's
Several other analog and digital consoles
d&b J Systems
L'Acoustics V-Dosc systems
Home: Compaq Z800
Dual XEON hexes
48G Ram
Windows 10
Midas M32 and XL48
Genelec 8050's with Genny sub
Genelec 8030's
JBL L96 & LSR32
Old 01-04-2007, 01:14 PM
but I made monitor on this desk and I don't use mastr fader ( mix L/R) only aux send and mayby is some trick to control level of monitor knobe to the master fader in yamaha is pm5 rh i can use some trick and do cue level on fader
new version digigo have monitor to master fader switch
thx
Old 01-04-2007, 02:53 PM
Sorry I misunderstood what you were trying to do.
I don't think it's currently possible to use the master fader as a solo level but I agree you should be able to do this. It's just a matter of patching the solo bus to the mains fader. How bout it software boys?
-Steve
Work
Twin S6L's
PM-10
Profile, D-Show
d&b J Systems
Home: Compaq Z800
Dual XEON hexes
48G Ram
Windows 10
Midas M32 and XL48
Genelec 8030's
JBL L96 & LSR32
Old 03-31-2007, 12:46 PM
mixFarm mixFarm is offline
only with a trick: i suggest you do not use the L/R bus. route the monitor outs to a AES output. a XLR cable to a AES input. patch these inputs to a stereo channel and set the routing of that channel to LR. put that channel somewhere not important on the console, make it automation and solo safe, and you are in business!!! set the levels right and you are done. you can patch the inputs to more channels and use them for more monitor busses over direct outs!!! very cool!!!
i hope that helped and showed you the big possibilities of the console.
Old 03-31-2007, 09:37 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Good suggestion. A few other ways to do this are covered in this thread.
Sheldon
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 05:36 AM
Monitor Control Plug-In for Master Fader? Archmart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 11-27-2005 09:46 PM
Master Fader 6.7 Master Fader issues Bogner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-19-2005 07:42 AM
DIGI: Will it ever be possible to implement Pre-Fader Inserts on the Master Fader? Ricky Cobble Pro Tools TDM Systems (Mac) 5 05-05-2003 04:47 AM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 07:41 AM
