Old 01-01-2009, 08:53 AM
jhorsley jhorsley is offline
Default Optimal playback instruments/soft synths in PT 8
OK! Working in pro tools 8 LE, and I would love to see how other programmers/composers are setting up their playback engine settings, specifically to stream samples.
My setup
DIGI 002 (apogee rosetta 200 external clock)
MAC PRO 8-core 2.8mhz
8 gb ram
PT 8
samples on external hard drive via FW800
complete toolkit
I have found the LEAST interruptions and optimal playback buffer with the following setup:
H/W buffer size: 256 Samples
RTAS Processors: 6 processors
CPU Usage limit: 99%
DAE playback buffer: Level 4
Cache Size: Large
Plug-in stream buffer: Optimize for streaming content on audio drives
I've got a lot of things loaded: Stylus (6 tracks), trilogy (1 track), Hybrid (1 track), Sampletank 2.x (3 tracks), quicktime video in session
I am still getting some crashes and errors, such as:
1) Audio stops playing when loading new samples in stylus, and then pt crashes a few seconds later
2) The option+select and drag midi note does not work consistently (this seems to be a bug in pt 8, regardless of playback engine settings)
3) Got an error "playback engine missed a deadline" before a crash. That's funny! I look forward to using that one myself with my clients
QUESTION FOR DIGI OR OTHER USERS:
1) Would more ram (more than 8 ghz) solve any of these problems?
2) Should my DAE settings be altered?
3) Would I see less problems if samples were streaming from a SCSI drive?
I'd love to hear what other users are doing.
Happy New Year,
Joachim
Joachim Horsley
www.LittleHorseMusic.com
Old 03-03-2009, 06:10 PM
affliCted affliCted is offline
Default Re: Optimal playback instruments/soft synths in PT 8
Id like to know the answer to this also!
Old 03-04-2009, 08:23 AM
DigiTechSupt's Avatar
Do you have any other plug-ins in the session and, if so, which ones?
Can you post a plug-in version list using the Tech Support Folder/Utility, so we can see what you have installed? All installed plug-ins can have an effect on the system, even if they're not being used in the session.
When you say 'Stylus', I'm assuming you're talking about Stylus RMX, yes?
I do know that Sampletank is a bit problematic and I would be curious if your performance improves once you remove it. However, I'd like to see your installed plug-in version list first.
Can you be more specific about what you're seeing, how you're editing, etc? Do you possibly have real-time properties enabled?
Avid Audio Tech Support
Support FAQ
Old 03-04-2009, 08:58 AM
cheeseandpepper cheeseandpepper is offline
I too have seen this. I have a new mac pro keyboard (which is totally different from my g4 keyboard) so im not sure if im letting go of the option key too soon, but it seems if i let go too soon the note will be erased instead being copied (which is why im pressing the option key) or just moved (which is what i'd expect if i let go of the option key too soon)
Does the software have the ability to define a range of "accuracy" with modifier keys?
i think thats what you mean, right?
2.8 Ghz (8-Core) Mac Pro
8 Gigs Ram
PTLE 8.0
Old 03-19-2009, 08:03 AM
phenom phenom is offline
My setup
8 gb ram
PT 8
complete toolkit
Cache Size: Large
Happy New Year,
Joachim
bump
Would really love to see some answers to this......
Old 03-19-2009, 04:08 PM
Megaman Megaman is offline
hope i am not interrupting your thread, but can the earlier digi support comment below be clarified?
"Can you post a plug-in version list using the Tech Support Folder/Utility, so we can see what you have installed? All installed plug-ins can have an effect on the system, even if they're not being used in the session."
1. what is meant by Tech Support Folder/Utility - where is this folder/how to access it please?
2. the second sentence is interesting - i have a lot of plug-ins on my computer which i dont use - is this saying that even if they are not instantiated in the session and not being used, that they can have some draw on pro tools? If so, how to identify which plugins have this effect?
I am on Power Mac G5 Dual 2.3 with 8.5GB RAM, using PT 8, with Stylus RMX latest. Have tried using just one instrument track with only RMX installed and then played with several combinations of playback engine settigns but RMX wont run for more than a minute or two before it stalls. Dont know if this is my Mac specs or something to do with the points tech support mentioned., so would be interested to hear clarification. Cheers.
Old 03-19-2009, 04:36 PM
Trilogy is not compatible with Intel Mac and very likely could be the cause of a lot of your issues. Sampletank has a few issues as well - you might want to try removing it from your plug-ins folder, trashing prefs and testing again.
Links can be found in the General Troubleshooting thread.
Yes, they can. Identifying them? Start with the Pro Tools Plug-In Compatibility Grid and make sure you have the minimum version required. Some plug-ins on that list may still need to have you drop the number of processors in the playback engine to get good performance (such as most IK plug-ins, Omnisphere, etc.).
Can you be more specific?
More RAM would unlikely help at all.
DAE Settings look ok - Level 2 on the DAE Playback Buffer is usually where you'd want it set unless there's a good reason to do otherwise.
No, streaming from SCSI is unlikely to improve anything.
Support FAQ
native instruments soft synths with PT8 dlap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-25-2009 04:20 PM
Soft synths jam on stop of playback pogo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-03-2005 04:32 AM
OSX PT6 Native instruments & Other Soft Synths Kitch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-14-2003 01:47 PM
Synths Samplers Soft Synths, Akai MPC4000 Still No SSL Yet Pro Tools TDM Systems (Mac) 6 07-11-2002 08:02 PM
Using Separate Computers for Soft Instruments/Synths Mr_Seven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-01-2002 08:29 AM
