Old 06-27-2012, 02:52 PM
Blake Henderson Blake Henderson is offline
Default Pro tools 9 won't load as HD! Have a core card installed and an HD license on Ilok
Hi all.
I recently upgraded to lion and did a fresh install of my entire system. Now when I open pro tools it loads as Pro Tools 9, where it loaded as PT HD up until now. I no longer have my core card/Apogee Symphony option in the "Current Engine" drop down. Also, I no longer have VCA mixing and Trim Automation. All of my sessions are forced to coalesce the trim automation into the Volume automation.
What gives!? Any one else have this problem? I've reinstalled PT 3 times and also installed all HD drivers.
help!
blake
Clumsy Congregation
Old 06-27-2012, 04:30 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Default Re: Pro tools 9 won't load as HD! Have a core card installed and an HD license on Ilo
Can you sign into your Avid Account? If so and you have PT HD 9 registered, it will allow you to download it from the website... Uninstall the version you have COMPLETELY, then after downloading install the Drivers you need for HD, for MIDI, and for External device... then install the downloaded version...
That should fix it.
Old 06-27-2012, 05:05 PM
Thanks for the help. I have done that, however. I've installed the 9.0.5"full installer" seevral times in fact, after doing a clean wipe of my drive. No luck. Still only loads as PT 9 without all of the features Ive been using for years.
Damnit.
Clumsy Congregation
Old 06-27-2012, 05:36 PM
Craig F Craig F is offline
if you hold down the N key when launching Pro Tools will it see your HD cards?
Thank you,
Craig
Old 06-27-2012, 06:58 PM
Nope. They don't show up even then.
Clumsy Congregation
Old 06-27-2012, 07:15 PM
so on your iLok do you have the 9 HD combo bundel that has both 9 and 9HD or do you have the separate 9 and 9 HD licences?
Thank you,
Craig
Old 06-28-2012, 10:58 AM
I have the bundle on the ilok.
UPDATE:
Installing the pt10 software (demo) solves the problem and my core card works in that version. Is it possible that My pt9 system is simply not hd, but only pt9? My understanding was that the installer contains both.
Clumsy Congregation
Old 06-28-2012, 11:51 AM
that is my understanding and experience
maybe e-mail iLok and ask if there is some way to test the HD licence for corruption
Thank you,
Craig
Old 06-29-2012, 10:34 AM
Folks, I still have no luck.
I have emailed Ilok and they simply tell me to get intouch with avid. I don't want to spend money to get support from them.
Why is my PT9 install not loading into HD?! I can't use my Core cord or any of my HD features! ITs maddening. Has no one else dealt with this before?
Blake
Clumsy Congregation
Old 06-29-2012, 10:44 AM
UPDATE:
In my ilok account it says "No Iloks found" even after "synchronizing" as well as installing all current ilok software.
Could my Ilok be partly broken? It loads PT9 without a hitch, but not HD.
blake
Clumsy Congregation
ilok - Cannot download license: Pro Tools 10+9 Bundle requires surrender of license soukotta Pro Tools 10 10 09-25-2012 07:22 AM
FS: Pro Tools HD1 HD PCIe Accel Core Card with HD8/HD9 iLok AND Mac Pro Northjersey Dan Buy & Sell 0 08-31-2012 12:21 PM
NO iLok License Card with GSM format license chip willy wonka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-19-2007 10:26 PM
My PC locks up after I installed the card, I didn't even load the software yet! HELP MikeD19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-15-2000 11:34 PM
