Old 11-01-2015, 03:04 AM
brad383music's Avatar
brad383music brad383music is offline
Default Can i use 11R as a DI box?
Sorry if this has been asked a thousand times but I cant find any info searching the forum.
Im trying to use 11 as a dedicated DI/audio interface in Pro Tools 9. I want to use Pod Farm for a specific track using a specific amp. I can add the plugin fine but when connected through 11 I also get a clean track coming through into the mix. Ive disabled everything i can think of inside the 11 and have tried all of the input options inside pro tools to no avail. I'd also prefer not to Re-amp.
Am I missing something here, or is it just not possible to do. Do i need to use an Mbox or similar instead?
Eleven Rack + ERXP
Pro Tools 9
Windows 7
Gibson Guitars
Washburn Guitars
Michael Kelly Guitars
Yamaha Bass
Roland TD30K
EZ Drummer 2
Superior Drummer 2.2
Old 11-01-2015, 02:39 PM
ThunderKyss ThunderKyss is offline
Default Re: Can i use 11R as a DI box?
I'm sure there is a way. I'm not at my rig right now, so I can't work out a procedure for you. But there is a way.
MacMini OS x 10.14.6
Core i5 2.5 GHz 16GB
Eleven Rack
Old 11-01-2015, 03:04 PM
Benoni's Avatar
Benoni Benoni is offline
You should have no problem using a Guitar amp sim plugin with the Eleven Rack. You want to choose GUITAR for the input of your Mono Audio track.
If you are hearing the dry guitar in conjunction with the plugin, maybe you have this problem?
https://www.youtube.com/watch?v=TbRnyt6PVjc
Other things to try would be Default the IO
https://www.youtube.com/watch?v=rxZ9SgQm8H4
Trash Preferences
https://www.youtube.com/watch?v=iyeFhIO64bE
As long as you are using Pro Tools as your DAW, this should not be an issue. I use the Eleven Rack like this all the time.
Another option would be to record the part with the Eleven Rack and benefit from the better response of hardware, then just place the plugin on the dry guitar track, no re-amping needed. Be sure to record the dry track at that same time as you record (or monitor) your wet Eleven Rack sound.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 11-07-2015, 03:56 AM
Trash Preferences
So I finally figured it out and I feel like a bit of a dill. Turns out I was trying to use the plug in in dual amp mode but one amp was not switched on! Hence the clean sound coming through. On the knob-ometer scale I'm turned all the way up to 11! Thanks for your help though. As always, you are super helpful.
Eleven Rack + ERXP
Pro Tools 9
Windows 7
Gibson Guitars
Washburn Guitars
Yamaha Bass
Roland TD30K
EZ Drummer 2
