Old 11-20-2013, 06:07 PM
kat768 kat768 is offline
Default C24 console and Digi Rack 003 communication issues.
Hi Guys,
I finally complained enough that my program chair has given me the green light to finally set up a 5.1 mix lab at my school.
I have pro tools 10 LE, 003 Rack +, C24 console, a Furman PL-Plus Power Conditioner, five 5" Blue Sky monitors and I would say a 12" Blue Sky subwoofer running into a Blue Sky bass management interface and controller.
As far as I can tell with my intermediate knowledge of routing, daisy chaining etc. everything is connected correctly. What's happening is the C24 doesn't show up in the hardware or playback engine menu under Set Up, nor am I able t hear any sound when creating a stereo session through any of the speakers. The console continues to say offline and I can't seem to get it to connect.
I have the ethernet cable from the console connected straight into the mac tower. I read someone's reply on the DUC that stated running the ethernet into a crossover of some sort, but not clear why that would change anything. I also tried to find an updated version of he driver for the C24 but could not find anything.
Anyway guys, if you've read any of my other posts you'll know that I am trying my hardest to approach every opportunity to better my skills and will exert all option prior to reaching out. I.O.W, I totally respect the engineering/trouble shooting aspect of what we do, and am humbly asking for a little insight and guidance.
And as always, your responses are GREATLY appreciated!!!!
Old 11-21-2013, 04:52 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: C24 console and Digi Rack 003 communication issues.
Originally Posted by kat768 View Post
Hi Guys,
The drivers are built into pro tools
Have you gone to setup>peripherals>ethernet controllers and scanned the ethernet ports to find the C24 then select the c24 in the ethernet port box. that should be it and the c24 will come online. if not try a different ethernet cable if its a cross-over ethernet cable.
The C24 is not an interface you will have to use the 003 as the interface and connect the audio connections from the 003 to the monitor input section on the C24 to use the monitor section on the C24. you will probably need to get the correct audio cable to do this. called a digi snake which will have the 25way D connection on one end for the C24 inputs and Jacks on the other end for the 003 outputs.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-21-2013, 07:53 AM
Great insight! It worked!
Now I am unable to get the session to output signal to all speakers. It's only outputting signal to the left front and center in a stereo set up. I tried importing the c-24 mix and stereo I/O settings; as well as opening the session and selecting not stereo mix, but c24 in the quick start menu. Would you happen to have any insight on this new found issue?...
...And thanks a bunch for your last comment!!!
Eleven Rack communication issues under OSX 10.9 lbar11 Eleven Rack 25 01-03-2014 04:37 PM
Digi 003 console, comand 8 or digi 003 rack plus boabyd23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 04-28-2011 04:13 PM
Digi 003 Rack Buffer Size and communication problems on Leopard BGPeres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 06-18-2010 10:36 AM
digi 002 rack issues tokunbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-24-2007 11:19 AM
DIGI 002 rack versus 002 console Death Bringer General Discussion 2 01-26-2004 08:16 AM
