Old 03-09-2010, 10:02 AM
Berkesound Berkesound is offline
Default D-Command Memory Reset
I've tried a forum search and haven't found any obvious answers. Our D-Command (8 fader) is resetting to factory default every now and then. We completely power off the unit every night so perhaps that's part of the problem. Normally this works fine. But maybe once every 2 months or so it will fully reset its memory-- all user prefs, all calibration data, etc. Is anyone else having this problem? Do you all leave your ICONs on overnight?
Thanks in advance for any help.
-Stephen
Berke Sound
San Francisco, CA
www.berkesound.com
Old 03-09-2010, 01:07 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: D-Command Memory Reset
Hi Stephen,
Strange one. You are sure you're not doing this accidentally yourself by deleting all pro tools settings / prefs and then having to reassign the unit right ? This happens completely out of the blue ?
Can you get us your system details ? OS / PT version etc.
Also , what firmware version is your unit on ? You can find this under the Ulility Switch > System > FW ver :
If you press and hold down the FW version switch you will see comm and motor Firmware versions. Do they match and witch are they ?
Can you think of anything that would lead up to this reset ? Again ... you're not deleting / reinstalling software or something like that right ?
Apologies if this sounds obvious but we have to eliminate user error
Thanks
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 03-09-2010, 01:57 PM
Thanks for the response. Yeah, definitely no changes as far as prefs, installs, or peripherals. We were using the system normally last night. It just turned on in factory default mode this morning.
System:
HD2 PCIe
2 x 3ghz Dual-Core
7gb of RAM
OS 10.5.8
The protools was version 8.01, however I just upgraded to 8.03cs1 in the hopes that it will solve the problem.
COMM and MOTOR firmware both read 8.0.0.314. XMON FW is 11.
We had a power outage last week-- but it was working fine after that. This is the 3rd time this has happened in the span of a year. Not the end of the world, it's just annoying to have to re-calibrate.
Thanks!
Berke Sound
San Francisco, CA
www.berkesound.com
Old 03-09-2010, 01:58 PM
Also, a bit unrelated but has digi discontinued digitest? It seems to now be missing from the PT folder.
Berke Sound
San Francisco, CA
www.berkesound.com
Old 03-11-2010, 06:39 PM
Bump. Any thoughts? Prior experience?
Thanks.
Berke Sound
San Francisco, CA
www.berkesound.com
Kontakt Memory Server (KMS) Could not start MemoryServer. Memory Extension will be... John_Toolbox Virtual Instruments 5 12-29-2011 10:03 AM
Reset Pro Tools Memory? acacia Pro Tools TDM Systems (Mac) 1 11-10-2010 08:19 PM
How do I reset the meter on Command|8? mrllnfn ProControl, Control|24, Command|8 3 03-17-2007 05:17 PM
Promting lack of memory on PC with adequate memory! Any tips? will22 Digidesign Hardware & Software 12 09-20-2001 08:36 AM
Reversed Keyboard command for changing Memory Locations now in PT 5.0 Mick F. Cantarella Pro Tools TDM Systems (Mac) 1 01-23-2000 05:37 PM
