Old 10-30-2019, 05:36 AM
LDS LDS is offline
Default 5.1 channel order wrong.
Hey everyone,
I'm having a slightly weird issue with 2019.6. Whenever I import 5.1 audio, the centre channel ends up on channel 1, top of stack in the edit window waveform view... coming out the left speaker.
My I/O and monitor patch are both set to 5.1 SMPTE. I can't figure it out.
Please haaalp.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 10-30-2019, 07:45 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: 5.1 channel order wrong.
Split the track to mono. Then reorder the mono tracks from top to bottom to a 'film mode' order (L, C, R, Ls, Rs, Lfe). Select all these mono tracks and drag it into a (new) 5.1 track.
You can 'consolidate clip' to make a proper file if needed.
Your source file may be wrong, could have been exported alphabetically ("c" being the first track), or whatever went wrong, this is the solution
ps. the I/O setup, output settings or 'path order' settings have no effect on the Protools track/bus order which is always 'film mode', so always sort as film mode.
HTML code is On
5.1 file channel order marcelkavka Post - Surround - Video 21 12-19-2018 09:35 AM
CAF channel-order still wrong in 9.0.5 Arno Peeters Post - Surround - Video 3 07-26-2015 07:55 AM
Locked Channel order in Bus bcslaam Pro Tools 11 3 08-29-2013 12:11 PM
OMNI 7.1 order wrong? David Sandwisch Pro Tools HDX & HD Native Systems (Mac) 8 07-16-2013 11:24 AM
AC3 file created w/Compressor had wrong byte order John McDaniel Post - Surround - Video 3 02-15-2007 05:52 AM
