Old 11-21-2019, 05:31 AM
nickosound nickosound is offline
Default Automation doesn't follow fade adjustment.
When i use the grabber tool to pull out a fade, or adjust the position of a crossfade the automation doesn't follow as normal. The same happens when i use the smart tool to create a new fade. Automation follows edit is on. Am i missing something or is there a serious bug with basic editing functionality?
this seems to have only started since upgrading to 2019.10
Old 11-21-2019, 04:47 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Automation doesn't follow fade adjustment.
Hi, Crossfades are separate from automation and are applied to the clip, so you won't see a fader move during a crossfade. "Automation Follows Edit" has to do with whether or not the automation associated with a clip follows the clip when edited - such as when you cut and paste a clip, the automation will follow that clip if that option is enabled.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-22-2019, 03:15 AM
Hi Chris, thanks for your response.
To be clear, when i nudge a fade on a clip using the keyboard commands it moves the level automation breakpoints with it, but when i manually move a clip fade using the grabber tool the breakpoints do not move with it.
PT 2019.10
Old 11-22-2019, 03:18 AM
Hi, welcome to the forum. Any chance you could post a screenshot of the two situations that seem to function differently?
Old 11-22-2019, 04:07 AM
i hope this gif makes the problem clear.
https://imgur.com/a/eIjlWLb
thanks
Old 11-22-2019, 05:26 AM
simonchase simonchase is offline
That doesn't look good.
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 11-22-2019, 09:38 AM
The Weed's Avatar
The Weed The Weed is offline
AFAIK, the automation points are moving with nudge because they are within the highlighted area. Highlight a node away from the fade and use nudge. The node should move. When you use the Grabber Tool to change the fade, you are only moving the fade edge, not the node or nodes under it.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-22-2019, 02:03 PM
cwsand's Avatar
So moving or adjusting the fade must not be considered an "edit" by design.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 12-02-2019, 02:44 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Automation used to move along with the fade as long as the automation was at the fades edges. This behavior is new since 2019.10. I regard this as a bug. A big one.
Old 12-02-2019, 03:04 AM
Thank you. I thought I was going mad.
Sent from my SM-G975F using Tapatalk
PT 12.8 send level doesn't follow the automation mgoorevich Post - Surround - Video 6 07-18-2017 08:55 PM
Automation doesn't follow clips (bx_control) Frank Kruse Post - Surround - Video 0 11-02-2012 08:39 AM
BUG: automation doesn´t follow Frank Kruse Post - Surround - Video 79 01-07-2012 11:59 AM
BUG : Plug automation doesn't follow tombob Pro Tools TDM Systems (Mac) 2 02-04-2011 09:08 AM
aux won't follow master fade automation 001fran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-29-2002 01:34 PM
