BBOD for 30 sec + after pressing play
Hi!
At work we have a huge annoying problem. We have a HDX MADI (128 I/O) system with PT10 (i tried every version from 10.2 - 10.3.7) on OSX 10.7.5 ( also tested on 10.7.4) on an officially supported MacPro with 12 GB RAM. We mostly use is as a multitrack, around 64 tracks I/O, no plugins, each track has its dedicated in and out. When we record orchestra rehearsals for our TV show, we get many takes with a length between 1.30 to 5 minutes. This results to a timeline length up to ca 75 minutes (48/24). Recording itself works just fine but pressing playback often results to a Beachball which holds off PT to play for 30 sec - 1 min! After waiting it starts the playback with no error message. I think the bigger the timeline gets the more often it happens. During the beachball i mentioned in the Activity Monitor app that the harddisk starts to read AND write something (about 20MB/s read and 20MB/s write), so the harddisk activity is HUGE and prevents PT to play back audio. Suddenly this behaviour stops and PT starts playing. This happens regardless of the device i use in the Playback Engine (HDX, MBox Pro, Mac soundcard). I tried simply everything from repair permissions to disabling network, every performance suggestion from Avid (spotlight off f.e.) is done... Does anyone else on this planet have this problem?
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: BBOD for 30 sec + after pressing play
How is the size of the Disk Cache/Buffer Size when playing?
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
I tried every size between "normal" and "13 GB". No difference.
btw, even 13GB would make Disk Cache senseless because it would just cache about 3-7% of the session.
And buffer size: i tried every setting, but the buffer size doesn't make any sense on HDX systems, because it only takes effect when you use native plugins. And we don't use any.
Is it possible to play a click without pressing play, and have it in sync.... | ALowe | macOS | 5 | 06-05-2011 04:24 PM |
Pressing Play or Record, Nothing Happens?? | Rockdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-25-2009 09:54 PM |
4-5 second lag from pressing play, to output? | WannabeSQ | Pro Tools TDM Systems (Mac) | 4 | 12-16-2005 09:59 PM |
PT MIX|24 Crashing after pressing play... | Schatzi | Pro Tools TDM Systems (Mac) | 5 | 03-24-2005 07:56 PM |
Since PT 6, pressing PLAY only works sometimes! | toddamo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-24-2003 10:51 AM |
