Old 10-10-2018, 10:48 PM
charlie70 charlie70 is offline
Default PT Express / clip gain
PT Express does not include clip gain.
What is the easiest way to do the same operation?
Old 10-11-2018, 12:43 AM
Sardi Sardi is offline
Automate the volume on the track. Automate a trim plugin on the track. Use the Audiosuite version of the trim plugin and render the gain change.
That’s three options that will do the same thing.
Visually, the last option will get you closer to a clip gain workflow, but the gain change is destructive.
I wouldn’t do it like the first option as if you want to raise the volume of the track, you’ll be dealing with all the automation.
Hope that helps.
Old 10-11-2018, 08:19 AM
Default Re: PT Express / clip gain
The Audiosuite GAIN plugin was my solution before Clip Gain was an option
Old 10-11-2018, 10:32 AM
JFreak's Avatar
JFreak JFreak is online now
Yea, and to OP, welcome to the community :)
Janne
Old 10-11-2018, 05:01 PM
Sorry. I meant Audiosuite again not trim.
Brain fart.
Clip gain o Gain plug in Camilo Toledo Foro en Español 3 03-22-2017 02:10 PM
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
