Circuit Buzz?
Hi all,
I'm getting a very annoying high pitch buzz (on recorded audio) when I create a circuit with my piano. I have a protools midi channel with the piano notes which I send to my piano (Roland HP505), then I run the piano output into the laptop (windows, via MBox 2). When I disconnect the usb connection the audio feeds perfectly (obviously I have to play it manually as the midi is no longer sent to it) but as soon as the usb lead touches any metal part of the laptop the buzz starts. So I have isolated it as some sort of electrical current / circuit that needs to be fixed. Is there some way to remove it? I tried running the laptop on battery instead of mains but no difference. Obviously I don't have this option with the piano. I have disconnected all other power cables Apologies if this is the wrong forum for this - any help would be very much appreciated. Driving me nuts! I'm in Ireland and my mains connections are grounded (I think!). Thanks, Steve. |
Re: Circuit Buzz?
Classic ground loop symptoms.
Do all the usual ground loop mitigation things. A good detailed explanation of what causes this and how to address it is here https://www.youtube.com/watch?v=GS-6jBk9YPM |
Avid Profile Fader Bay Circuit Boards failing | [email protected] | VENUE Live Sound Systems | 1 | 12-13-2015 11:07 PM |
Stompbox Neve 1073 modeled circuit recording preamp | VRW | Tips & Tricks | 2 | 11-17-2014 10:19 AM |
Need conversion from 6-circuit firewire to 4-circuit socket in laptop | chirnover | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-09-2010 03:23 AM |
Does Digi sell the Fader circuit board for the 002 | Ormond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-17-2010 07:36 AM |
Eq or other plug in 'in circuit'? | RaySoul | General Discussion | 8 | 01-23-2010 11:51 PM |
