Old 09-24-2012, 01:31 PM
simonyeah simonyeah is offline
Default Monitoring input and track during playback
I record vo very often and always faced to a problem: the talent record a track and then wants to listen what he just did, but when I playback, very often, he says things that I cannot monitor as the track is playing and therefore the input is not available.
Is there s a way to achieve this : monitor both the input and the content of a track when playing back?
Thxs in advance
Simon
Old 09-24-2012, 01:45 PM
Henchman Henchman is offline
Default Re: Monitoring input and track during playback
Create an auxiliary input that is also being fed by the mic. Mute that when you record, unmute on playback.
www.markhensley.tv
IMDB Credit List
Living the dream.
Old 09-24-2012, 01:46 PM
tj_davies tj_davies is offline
Originally Posted by simonyeah View Post
Thxs in advance
Simon
I always habe two tracks when I record vo. First track named "first name.01", the second track right underneath named "sur name.01". Before the vo comes I make sure I have plenty of playlists for the surname track and maybe about 8 for the firstname track.
I record the vo to the surname track, each take a playlist. This track stays Input only throughout the recording time. Whenever the vo or client want to hear a take I pull it up to the first name track. For the next recording I change the first name playlist to .02. This way, I can keep track which takes have been listened to. And I can edit vocal takes straight away during recording, without having to change the input monitoring mode. Punching in is easy as well, as the playback take doesn't sit on the record-armed track. So I don't have to change the recording mode.
Hope this helps,
Timothy
G5 10.8.5
PT 10.3.9 HD2
www.pearls-music.com
Old 09-24-2012, 01:50 PM
Dan Smith's Avatar
Dan Smith Dan Smith is offline
Lots of ways to do this. Here is one. Instead of using his mic as the input to the recording audio track, bring it into Pro Tools on an Aux Input. Then send it to the recording audio track pre-fade. I'll usually keep the Aux muted until I need to playback and hear like (like in the scenario you are describing) Hope this helps. Good Luck
Dan Smith
Re-Recording Mixer - Warner Brothers
Old 09-24-2012, 02:06 PM
Default
Great thanks for your tips.
Old 09-24-2012, 03:07 PM
Craig F Craig F is offline
http://www.pro-tools-expert.com/home...ng-issues.html
and a pulg for doing automatically
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
HTML code is On
Track Input monitoring!? realizment macOS 9 11-04-2013 01:51 AM
Input Monitoring: What if you ONLY want to hear playback? EricWillhelm Pro Tools 10 2 10-21-2011 11:05 AM
Playback engine & Input monitoring Stig Eliassen Pro Tools TDM Systems (Mac) 17 12-19-2010 01:24 PM
Monitoring your input during playback with DIGI002 stevethrewup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-15-2007 04:08 PM
monitoring input with playback brothers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-14-2001 10:45 PM
