How to get around an ilok?
This is the most obnoxious tool in the world. I am using really big projects in protools and am running into such a hassle when my ilok accidentally slips out or I need another USB port/need to transport my laptop somewhere. I normally have to wait about 25 minutes to reopen my project and its plugins.
Is there a way I can have it so that Protools won't lock up when I take my ilok out? |
Re: How to get around an ilok?
Hi
There is no other way as the ilok has to be connected at all time when using Pro Tools so sorry to say no other way. As Avid has chosen to use Pace / ilok as copy protection we have no other way to authorize and use PT except with iLok Christopher
25 minutes??
Invest in a new computer that doesn't take so long to load sessions, has more USB ports available, or buy a $20-50 USB hub.
WombatStudio.Org Digital Recording, Mixing and Mastering in Gibbsboro, NJ USA "It's not the gear ... it's the ear" |
Or switch to a DAW that doesn't require a dongle(like Reaper or Harrison MixBus)
I've told you a million times, never exaggerate!!
How can an iLok slip out? Get a dongle buddy and tape the iLok to your computer - that way it won't come out of the connector. |
Studio One
Besides just learning to love the iLok, or switching DAW completely, the other potential solution is to use Pro Tools LE.
Of course there are limitations (beyond the fact that the software has some features missing compared to newer versions, as well as, of course, in comparison to HD software) in that you would have to use specific hardware : Digi003 / Digi003Rack / Digi002 / Digi002Rack / Mbox 2 (mini, regular, or Pro) / Mbox 3 (mini, regular, or Pro) / Eleven Rack. and your computer OS would have to be compatible with whichever version of PT LE you were using. But you should have no problem running Snow Leopard, or Windows XP, and Pro Tools LE 7.4 or 8. It's another option if you want to stick to Pro Tools, and not deal with an iLok to authorise the software. Of course, you may find you rely on some plug-in's that do require iLok authorisation, and then you're back to square one. |
I've got daws and apps the use ilok, and some that use license files, and some that use question and answer, to authorize them. In all honesty the ilok is possibly the easiest.
I've changed computers a couple of times in the last year or so. And everything that was on the ilok I simply reinstalled. Everything else I had to deauthorize, which is sometimes easier said than done, install and then reauthorize. Which again can be a headache. And heaven help you if you forgot to deauthorize something before getting rid of the last computer. And ilok isn't perfect. But it really is pretty convenient. And more to the point. Why does it take so long to re open a session? Maybe an SSD would be a worthwhile investment. Along with a USB extension cable. :)
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
error: missing ilok authorization for pro tools... please insert the necessary ilok. | Witold.B | Pro Tools Express on Mac OS X | 1 | 04-21-2014 03:59 AM |
ilok issues - ProTools 9 crossgrade LE (Please install the iLok Client Software) | pauledwards | Windows | 3 | 09-10-2013 04:02 PM |
Plugin auth weirdness - guest iLok prevents internal iLok? | Scott Helmke | VENUE Live Sound Systems | 3 | 09-07-2011 07:06 AM |
Can You Transfer iLok Licenses To A New iLok If Your Old iLok Is Broken? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-07-2009 03:51 AM |
Transfer iLok auth. from old iLok to new 003 factory iLok? | lamp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-20-2007 07:05 PM |
