MacBook 13 inch, i7, 2.9 ghz, 8gb
Hi Everyone.
I'm interested in the 13 inch MacBook with: The 2.9GHz dual-core Intel Core i7 Turbo Boost up to 3.6GHz 8GB 1600MHz memory 750GB 5400-rpm hard drive1 Intel HD Graphics 4000 Built-in battery (7 hours)2 And detailed more fully in this link. http://store.apple.com/us/browse/hom...ly/macbook_pro I'd like to run Pro Tools 10 on it, but I also wanted some general info. I know Macs and Pro Tools have always worked well together. Will Pro Tools 8 and 9 work equally well? Are there any traps I need to be aware of? Have any of you tried PT 10 on this MacBook? I hope this is posted in the right place. Thanks in advance for any info and suggestions you can offer. Don |
Re: MacBook 13 inch, i7, 2.9 ghz, 8gb
That setup will run beautifully with Pro Tools 10 for sure. I would not rely on 8 or 9 to work.
Good Luck! |
Thanks for the reply. Since I already have PT 9 I thought I would investigate the possibility of being able to de-authorize it from my older computer and use it on the new laptop without having to buy more software. But I'd really like to have PT 10 now. BTW....I have a really nice MBP 17" that I got from an engineer in Nashville that does a really good job of running PT 9. If I buy PT 10 can I put it on two machines?
Thanks again! Don |
No Problem!
Yes you can run pro tools 10 on multiple machines but not at the same time as you will need an ilock to start up pro tools. I have seen some people say 9.0.6 runs on mountain lion but i think springing for the upgrade to 10 is worth it especially for clip gain |
Sounds like PT 10 is the best choice! Thanks for the help!
Don |
MacBook Pro 13 Inch is Dual Core | smoothbassman | macOS | 5 | 02-11-2013 06:05 PM |
15 or 17 inch New Macbook Pro? | cary chilton | macOS | 14 | 03-23-2011 02:15 PM |
MacBook Pro 15-inch i7 with SSD on order...how to best install software? | Guitarman002 | macOS | 4 | 12-12-2010 09:07 AM |
Which is better? (New) MacBook Pro 15 inch or 17 inch | Hookshot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 07-21-2009 09:07 PM |
They're Here! MacBook Pro - 17-inch | coolcat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-24-2006 02:20 PM |
