Mono check on 001
Greetings and thanx in advance for your time. Mbox has a nifty "mono switch." Nice for checking your mix in mono. So.....whazzzzup with PT 001. How does one check a mix in and out of "mono" with the 001 unit?
Mack Shack Studio |
Re: Mono check on 001
If you use a hardware mixer, which is the best way to take advantage of having 18 outputs from the 001, you use the mono button on the mixer. If not, you could use one of the many speaker switch/talkback modules currently available. I think there may be plugins you can insert on the master fader, but I'm not sure which ones will do it, I use a mixer. If you do a search, I remember seeing discussions about this in the past.
I have an idea. What about creating a stereo Aux which sends to the Master fader. Pipe your "subs" (if you set it up that way or all your tracks (lengthy)) to that Stereo Aux and then pan it to the center. Thus, outputing to the master fader as Mono!?
Mack Shack Studio |
The method with an AUX track is the best one.. but for REAL mono pan both tracks LEFT, not centre.
Mono should be checked on ONE speaker to not fool yourself.
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
Why check your mix in mono? | KevinAllen | General Discussion | 29 | 01-28-2010 01:15 AM |
How can I Check my mix in Mono? | Derekten | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-01-2008 01:57 AM |
Check Mono....? | danwillrock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-19-2007 04:10 AM |
how do I check my mono mix "in the box" | Ben Davis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 01-21-2007 04:34 PM |
mono check | uwehaas | Tips & Tricks | 4 | 12-07-2005 08:28 AM |
