Midi Time Code not working in PT11.3.0 (solved)
I often have a 2nd Mac for Logic running beside my MP which hosts PT. I'm doing the synchronization by transmitting MTC from PT to Logic and also I'm using MMC. MMC (Midi Machine Control) works, but Logic is not playing wehn in external sync cause it is not receiving MTC. Can someone confirm, that this is broken again ? See also this thread: http://duc.avid.com/showthread.php?t=348470
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 Last edited by Hanswurstlsepp; 02-13-2015 at 03:37 PM. Reason: Problem was in AMS and not in PT !!! |
Re: Midi Time Code not working in PT11.3.0
Do you have MIDI beat clock enabled for that device/connection? It's in the menu Setup --> MIDI --> MIDI Beat Clock.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Yes - tried with MidiBeatClock enabled and/or disabled. Doesn't make any difference.
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
The only other option is in Peripherals Sync setup and you most likely have that covered.
So are you saying that MTC is working with your PT HD 11.3.0 ?
And here's another thread:
http://duc.avid.com/showthread.php?t=328527 And here are some screenshots how I have it set since ages: In PT: https://dl.dropboxusercontent.com/u/...-SyncPrefs.png In Logic: https://dl.dropboxusercontent.com/u/...fsSettings.pdf
I have nothing set up right now that I can check. I do know that MIDI Beat Clock is working by watching activity. That's in 11.3.1. If I get a chance later I'll try to slave Logic locally via IAC.
Great - thx - in addition I will install 11.3.1 later tonite, too and see what's happening.
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 Last edited by Hanswurstlsepp; 02-13-2015 at 07:31 AM. Reason: typo |
At first I could not get it to work, but I had forgotten about enabling PT to generate MTC with the Sync options in the transport controls. PTE has a good video here https://www.youtube.com/watch?v=wbrNUuaux7k which covers everything. It works over IAC, but just substituting your MIDI port in Setup --> Peripherals --> Sync --> MTC Generator Port should work. I can select a physical MIDI port and it lights up my MTPAV (that's with MIDI beat clock disabled so I'm not seeing that).
Re: Midi Time Code not working in PT11.3.0 (solved)
Hi Chuck,
thank you so much for verifying !!!!! It turned out, that my "ProFireLightbridge" device in the AudioMidiSetUp was *somehow* corrupt. I'm using Unitors for Midi. After adding a new device and cabling it back to "Port#2" where the ProFireLightbridge from MBP is connected via Midi, Logic synchronized again and the Midi Activity LED of Unitor Port 2 is also showing that there's a continuously Midi signal ... finally. Thx so much again for checking that it is not broken in PT
Pro Tools Slaved by Midi Time Code or Midi Beat Clock | DarylBham | MIDI | 5 | 06-14-2009 01:55 PM |
"Bad" Midi time code? | Nawlins | Post - Surround - Video | 9 | 04-06-2008 09:43 PM |
Midi Time Code and LE 7 | jjsoundoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-29-2006 04:28 PM |
PT6 & Midi Time Code | bzldzl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 04-22-2003 12:38 AM |
Midi Time Code....PLEASE HELP!!!! | Rudger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-19-2002 08:27 AM |
