  #91
Old 05-03-2017, 04:34 AM
notable's Avatar
notable notable is offline
Default Re: HDX Latency
Originally Posted by martthie_08 View Post
This bug went away with ProTools 12 or are you still having troubles?
Still having regular problems. Delay comp is broken. Lets get avid to take this very very seriously.
Pt12.4 hdx, 64 gig ram 24 gig cached, 12 core only one track recording can cause it. Yes occassionally restarting helps but thats BS in a pro environment. Please fix this.
Notable.com
AfricanUnderground.com
DemocracyinDakar.com
NomadicWax.com
  #92
Old 05-03-2017, 05:31 AM
arche3's Avatar
arche3 arche3 is offline
I'm curious. What is the cue mix being fed from? How are you sending the cue mix?
I've yet to have this issue.
Sent from my SM-G955U using Tapatalk
  #93
Old 05-03-2017, 03:27 PM
V5V's Avatar
V5V V5V is offline
Have you started a support case with Avid?
Lorin Schultz
V5V Audio
Vancouver, BC Canada
  #94
Old 05-03-2017, 04:30 PM
notable's Avatar
Not recently. I will try in few weeks when my schedule opens.
Notable.com
NomadicWax.com
  #95
Old 05-04-2017, 10:36 AM
V5V's Avatar
V5V V5V is offline
I realize saying this sounds like blaming the victim, but I ask about a support case because that's the only way to get Avid to "take this very, very seriously."
We can rant until we're blue around here and it won't make a lick of difference because no one who can do anything about it is reading this, and even if they were, this forum isn't part of the documentation path that eventually leads to resolution.
The way to get something fixed is accumulation of support cases. If no one reports it, Avid assumes it doesn't matter enough to get top-of-the-list attention.
Lorin Schultz
V5V Audio
  #96
Old 05-05-2017, 08:59 PM
Dan IceWood Dan IceWood is offline
Maybe try running the latest version 12.7.1, that does have the bugs fixed.
  #97
Old 05-07-2017, 04:51 AM
martthie_08 martthie_08 is offline
for me this bug disappeared completely with the move to PT12.
are you also experiencing this bug on new sessions that have been created from scratch in PT12?
maybe also try trashing preferences if you performed an update from PT11...
  #98
Old 05-07-2017, 07:42 PM
Guy McDude Guy McDude is offline
Yes, it shows up sporadically, new sesh, or old.
Trashing prefs, does not help.
A complete restart sometimes does.
thanks
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
www.seanmcdonald.com
  #99
Old 06-11-2017, 04:38 AM
notable's Avatar
Thanks for the feedback and I agree with the idea that direct discussion with TS is always helpful for the company and our issues. I will experiment with a newer OS and newer version of PT this week. I have waited on hold a few times while doing the trouble shooting but never actually spoke to a tech, but I will keep trying. I have spoken directly to some avid people who have known of the issue. I also post to ideal scale frequently so I'm am trying to keep the information in the public and avid arena. I rarely have time to trouble shoot, discuss it with tech support, do the recommended tests and get back in touch to report back with updated information. Usually I figure out a solution and get back to work. Todays approach is to make two new fresh start up disks with different os and matching recommended pt versions 12.4 versus 12.71 ( and uad versions) , optimize both for PT use and check the behaviors when changing between sample rate sessions and their delay cmp behaviors. It seems like in my case the hardware doesn't like the sample rate changes. The system doesn't switch between sessions with different sample rates gracefully( It requires recycling the system.... )so I'm curious if that plays a role in delay cmps sporadic inconsistency. Im also not sure the latency issues are the same as the delay compensation issues. Just so you know... I use no plugins on the auxes or master faders and the analog out of 7 channels go directly to a hearback system from auxes dedicated to each physical out. Thanks D
Notable.com
NomadicWax.com
  #100
Old 06-17-2017, 11:55 AM
notable's Avatar
So I finally cleared the schedule to trouble shoot this. As with many stubborn audio issues it was more than one problem. First the erratic behavior seems to have been an unhappy System drive that was not fixed by system reinstall. Booting from another fresh system drive helped stabilize the whole rig. With a new ssd OSX drive working I got a bunch of sessions through the door. I will test the latency issues with the new drives and new PT version 12.7.1 and put the info here. I am also pretty sure the sluggishness to change sample rates when moving from session to session was an artifact of the OSX drive having problems and the pt library files that were not removed by session changes, pt reinstalls or OS reinstalls. I will get back to testing changing the amount of HDIO's or Lynx Auroras and then the systems ability be consistent with the latency. So booting from a brand new, reformated fresh OS drive with fresh PT fixed many of the issues. Next we I will measure the latency and test various plugins and 'm tempted to rebuild my pt tracking template which includes my monitoring setup as well.
Notable.com
NomadicWax.com
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Piano VI's- Latency Latency!! MARVINBASS Virtual Instruments 5 04-27-2006 01:09 AM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
